Shifting problems
Old 05-01-2007, 02:13 PM
HIPER-Z's Avatar
Default Shifting problems
I cant shift down into second gear most of the time, i know that my clutch is toast, but just wondering if it could be more, i bought a new clutch. But what do ya'll think?
Old 05-01-2007, 03:19 PM
calhoon's Avatar
I don't think they are related as long as the clutch fully releases.
Old 05-01-2007, 03:24 PM
HIPER-Z's Avatar
It does, i dont think its the clutch, i am thinking that its the second gear syncro, becasue it wont let me shift down, i have to give it a little gas, or rev then pull it down into second, or shift into first then to second. It works fine going from first to second gear, its just going back down.
Old 05-02-2007, 06:27 AM
calhoon's Avatar
Well, the load on the synchro is higher on a downshift than on an upshift so you may have found the problem yourself---the 2nd gear synchronizer is worn out.
Old 05-02-2007, 07:31 AM
HIPER-Z's Avatar
Thats what i was thinking it may be, but where do i find a one? Should i just replace all the synchro's?
Old 05-02-2007, 10:48 AM
calhoon's Avatar
With the work required to get at the 2nd synchro, you would be best off doing a full freshening.
Old 05-02-2007, 01:17 PM
HIPER-Z's Avatar
Full refreshing includes what?
Old 05-07-2007, 11:32 PM
HIPER-Z's Avatar
Could this be the syncro's or could it just be the hydraulics?
Old 05-08-2007, 04:39 PM
HIPER-Z's Avatar
Anybody? Please
Old 05-16-2007, 01:58 AM
00JDAws6's Avatar
From my experiene dealing with these transmissions, I would say replace 1-2 sync 2-3 sync and 3 -4 sync along with carbon fiber blocker rings and if you have an 98- 00 a steel 3-4 fork. Also bronze fork pads on 1-4. No sense in having to replace 1-2 sync and having to pull the transmission later for another sync just do them all but if on a budget do 1-4 because most people dont powershift 5-6. But bronze fork pads are a definite because factory are paper, also a must is billet keys for 3-4 i think they are known to break.
Hope this helps
BTW t56 rebuilds will treat you good if you have to send it to them or do it yourself with their parts. They have excellent customer service.
Old 09-18-2007, 11:44 AM
HIPER-Z's Avatar
They just have a link?
Old 09-18-2007, 04:33 PM
JimMueller's Avatar
I sort of just went through this, except my shifter would go from 4th to neutral and no place else, and also intermittnet popping out of 2nd gear. Tear down showed I needed a new 1-2 slider and reverse slider (teeth worn off but no apparent drivability problem). If sliders not available separately then I would have needed to buy the entire synchro.
I spoke with Amber at Six Speeds, Inc and she gave me this advise. The 1-2 and 3-4 bronze pads are recommended (5-6 and R can be noisy), get the 3-4 steel fork if you don't already have it, and get the carbon fiber blocker ring kit. If needed, get a replacement top hat (the piece the shifter sticks into on top) and bearings.
Quick Reply: Shifting problems
