Sponsored by: DashLynx
Claybar tips
Old 05-07-2007, 08:36 PM
95FbFormula's Avatar
Default Claybar tips
Just bought a claybar today and would like some tips on using it. I know keep the surface lubricated but not much else.
Old 05-07-2007, 08:56 PM
95greenZ's Avatar
Be sure to wash the car before claying. Work the clay bar back and forth until the surface is smooth. As the bar gets dirty knead to a clean section, and if you drop the bar, just throw it away. Thats it and keep it lubricated like you mentioned, good luck.
Old 05-07-2007, 09:25 PM
Z28LS1camaroguy's Avatar
yeah lubrication and knead it whenever it looks alittle dirty, also make sure to wash your car off after and polish or wax it. Its not hard just really time consuming, i did it today and its great but takes awhile.
Old 05-07-2007, 09:32 PM
2001somws.6's Avatar
Ues clean car soap as the lubrication. It will take out more and is quicker.
Old 05-07-2007, 09:40 PM
^^^^^ that is true and it will save you money on not having to buy that spray ****.
Old 05-08-2007, 05:59 AM
SRT2LS1's Avatar
I usually clay as I wash, cuts a whole lot of time and makes sure the car is very lubricated. Just run your glove over a couple times and then run the clay over the same area. Works great for me...
Old 05-08-2007, 06:03 AM
Moderator
davered00ss's Avatar
www.meguiarsonline.com
www.mothers.com
both have a section about clay bars.
Old 05-08-2007, 09:25 AM
black01_WS6's Avatar
keep it wet, knead when dirty and you will be fine.
Old 05-08-2007, 09:56 AM
Avengeance's Avatar
The biggest tip you can give to a new clay user is do not use too much pressure. You just want the clay to glide over the surface... if you press too hard you can actually mar/scratch the paint with the contaminants already in the bar. Ive been detailing for a long while now and sometimes I find myself pressing a little harder then a should which makes more work for me when I get to polishing.
Old 05-08-2007, 11:12 AM
Well i just finished my first time and it turned out great I practiced on ym moms car lol its a lite gray with some flake in it wanted to try that before my black car, Looks really good to bad i don't have a camera but it was well worth the time after washing it with meguiars deep crystal car wash after the claying It looked as good as it did when I just waxed without claying. It cant wait to finish buffing and polishing to really see a difference.
Quick Reply: Claybar tips
