I had wet carpet on the passenger side???
I noticed about a week ago i got in my car to find the passenger seat carpet was soaked.... not sure wat this is from?? i just started using my ac heavily now...
but another question i notice after i have been using my a/c after i drive there is a rahter large puddle of water or wat ever under my car leaking i guess from the a/c compressor... is this right? should it leak that much?
Have you ever taken a can of compressed air an froze something? or used refredigerent and shook it, the can its iced over and has to defrost and travels down the passengers fender to the ground. might want to check to see if the plug is in the underbody of the car on the passengers floor board as well..
I had the same wet carpet and it was the heater core. It is pretty easy to change out on these cars, I hear that alot of other cars you have to pretty much remove the whole dash. In our cars it is behind the glove compartment and the hardest part was actually getting the hoses to break free from the core.
so wat actually happens to the heater core ? and wat does this bitch do?!
Originally Posted by tonydepo
I have water in my back passenger and not in front.. It rain like hell here the last 2 days. Think it is ttop or heater core?
Thanks
Thanks
Ok I just wet vaced it about 1 hour ago and im starting to get water in the back passenger feet. So it must not be a leaking t top. How do I get to the train tube?
Thanks
Thanks
In reference to the puddle in the back seat:
Was the car parked with the nose facing down? I remember reading on the board about that being a known issue if you leave the car parked with the nose facing down and it rains a lot. I think the easiest solution was to make sure you park with it facing up or level
Don't think it's the drain tube. The AC condensate drain is on the passenger side firewall and supposed to drip outside the car - when clogged it'll spill water into the FRONT passenger side - think something else is going on. If the drain is working correctly you should be getting a puddle under the car when running the AC. Get inside the car and have someone run a hose with fairly strong pressure along the weatherstriping on that side and see if you can find it.
Sat in the car and had my buddy use a garden hose on it and could not see any leaks coming from T tops at all. After about 5-10mins the carpet started getting wet again. I read on another ls board that it was a problem with the passenger sail. Trying to get more information. It might be leaking at the bottom of my molding at the corner of the door and seeping underneath.
Will see
Will see
