hid fog lights
hid fog lights
Hey every one I was wondering if anyone else has put HID fog light kits in? I just did mine and they look amazing. I have had one problem a 15amp fuse keeps blowing out? It wipes out my instrument cluster!!!!! I keep putting a new fuse in but that is not the fix! I think i will wire up a wire harness for them. Any comments????????
Thanks Hunter
Thanks Hunter
Ungrounded Moderator
Originally Posted by LS1_SS
You can upgrade the fuse 5-10 amps.
Originally Posted by 540inch Silverado
but i was wondering if anyone had wired them on a seperate circut while using the stock swtich.
Originally Posted by WhiteBird00
Not generally good advice. In this particular case the circuit is wired with 14-gauge or larger so it can safely handle some additional current (although I wouldn't put a 30-amp fuse in this 20-amp circuit). It is not usually a good idea to put a larger fuse in any circuit. This is especially true if it takes some time for the fuse to blow - any fuse will protect against a dead short but an over-current condition can cause a fire if the fuse is too large.
HIDs draw less power, only need the initial jolt on stat up, which is probably why his fuse is blowing. Granted I have never had to do it on cars, but every bike requires an 5amp higher fuse for the headlights.
