11 Second Club - In the 11's now
BOTTLEFEDLS1Z
05-10-2007, 04:37 PM
Went out to GIR here in STL on tues and ran a 11.86@120.94 with a 1.88 60'.
I could not come out of the hole for nothing. I'm running MT street radial and the best I could get was a 1.88 60'. I heated the shit out of them and dumped the clutch anywhere from 2500-4200 and they would either spin or bog real bad. I was told the 26" tire is hurting me with no sidewall and I know the car being lowered doesn't help either. Anybody have any other thoughts on why the car wasn't 60'????
I'm gonna put the stock springs back on it and take off the front swaybar and see how it does then. Coilovers are coming soon....
shortdog
05-10-2007, 07:40 PM
Yea, you went on the wrong night. Wednesday slick tire t&t is the time to go, because they prep the track much better. I will never run my car on Tuesdays again..
Get that 60' down and you should see low to mid 11s.
BOTTLEFEDLS1Z
05-11-2007, 03:28 PM
Yeah thats the plan..
h.o.ls1
05-13-2007, 10:47 PM
yea im thinkin that was my problem too....i couldnt get better then a 2.1 60 ft with mt radials at 17 lbs and heating the fuck out of them./....ill never go to another midnight madness again....only wednesday nights
98TADRIVER
05-14-2007, 08:14 PM
I'm running MT street radial and the best I could get was a 1.88 60'. I heated the shit out of them and dumped the clutch anywhere from 2500-4200 and they would either spin or bog real bad. I'm gonna put the stock springs back on it and take off the front swaybar and see how it does then. Coilovers are coming soon....
first of all they do not require "heating the f*ck out of them
secondly you cant go dumping the clutch, because you will either spin or bog.
Ive cut 1.8 60's on street tires before. for the M/T's, I heat them up for a couple of seconds, thats all that they require. after that i just clean em off after rolling thru the water. On the M/T's i came out of the hole at 4500 rpm, slipping the clutch quickly on 24psi. try a little finessing on your launches instead of dumping it because you will either ALWAYS spin or bog which= piss poor 60' times EVERY TIME. try not to go under 24psi, because it will only hurt you up top. (more drag from underinflated tire)
Before you go ripping your springs and swaybar out, try this, - 24psi, 5 second burnout. SLIP the clutch from 4000-4500 rpm and away you go. I hope this enlightens those who are having problems with their 60'
PS im not being a prick
BOTTLEFEDLS1Z
05-16-2007, 01:17 PM
I can tell that YOUR not being a prick. I appreciate your response.
I'll try what you said above, but I don't think the twin disk is gonna like being slipped
1bigcamdls6
05-16-2007, 08:14 PM
hey guys wanted to know what you think my 1/4 mile time should be if i could launch my car. my best 60' is 2.1 and clocked 12.0 at 120 and that was 35 hp ago.......added the fast 90/90 ported and got 35 out of it. im runnin 440hp now but i think the clutch is goin. if i had a good 60' time like 1.6 what time/trap speed do you think i could expect? btw tracked the car at 440rwhp but due to clutch slippage got a 2.5 60' and ran 12.4@125mph
98TADRIVER
05-17-2007, 02:22 PM
a while ago, i had a spec stage 3 clutch, which had basically no play to it, either in or out, but i got the feel for it after a couple of passes. youll get the feel for it with some more seat time. it just takes some patience. Ive never driven a car with a twin disc so i cant say how that feels.
98TADRIVER
05-17-2007, 02:24 PM
I would say low 11s, no doubt
a friend of mine is running 10.9 @ 126 with a 1.4 60'
