spec 3 clutch and flywheel install
Old 05-14-2007, 01:01 AM
roadhog_113's Avatar
Default spec 3 clutch and flywheel install
This week I will be installing a spec 3 clutch and flywheel. I have a 93 z28 with 415rwhp. Is their anything i should know before I start? I really don't know much about clutches and never worked on one but my dad is a mechanic and works with manuals all the time. Any advice would be appreciated.
Old 05-14-2007, 08:05 PM
to anyone who will be doing a clutch install here is a pretty good site with step by step explained pictures. My clutch will be goin in this saterday hopefully it all goes well.
http://www.gmhightechperformance.com...tallation.html
Old 05-16-2007, 10:05 PM
What kind of tranny fluid do u guys recommend?
Old 05-17-2007, 04:19 AM
turbologics's Avatar
the atf stuff and its red
Old 05-19-2007, 05:27 PM
ok so i just came back from installing the spec 3 and flyweel. But i got a couple questions.
When letting the clutch out now if i don't have my foot on the gas it will stall instantly is that normal? If i make my master adjustable will that make it more streetable?
Also driving home i noticed if you listen carefully you can hear a constant dinging, it sounds like a music box.
Please help thanx.
P.S. Getting that trans back in was retarded. Took a good hour at least.
Old 05-20-2007, 12:05 PM
Here are some pics of the installation. Still need some answers for the above please. (first time posting full size pics not sure if it will work)
http://i207.photobucket.com/albums/b...3/100_1475.jpg
http://i207.photobucket.com/albums/b...3/100_1476.jpg
http://i207.photobucket.com/albums/b...3/100_1477.jpg
http://i207.photobucket.com/albums/b...3/100_1479.jpg
http://i207.photobucket.com/albums/b...3/100_1480.jpg
http://i207.photobucket.com/albums/b...3/100_1481.jpg
http://i207.photobucket.com/albums/b...3/100_1483.jpg
http://i207.photobucket.com/albums/b...3/100_1484.jpg
http://i207.photobucket.com/albums/b...3/100_1485.jpg
http://i207.photobucket.com/albums/b...3/100_1486.jpg
Old 05-20-2007, 12:13 PM
brad8266's Avatar
Please help thanx.
It might help you out to have an adjustable master cylinder in there so that you can change the engagement point. The stage 3 is a more aggressive clutch and doesnt have as much give in it as a stock clutch, that is why you are stalling when it engages.
Im not sure what the dinging is though. Is everything tighented properly?
Old 05-20-2007, 12:32 PM
Ya everything was tightened. We couldn't find the torque specs for the pp so we torqued it to 35 ft lbs. First time we did it to 40 but we had to take the bell housing out again to make sure we could get the spline through(hell of a time getting that trans in) and the bolts were overtorqued so we re threaded them and put it all back together for some reason after we put it all together again the tranny was a lot easier to get in. We had to get a couple bolts started and gently pull the two together by tightening them. It seemed to just be getting hung up on the left side key on the bellhousing.
Also After it was all together my dad tried the clutch to see if it was ok. He pressed the pedel down and heard something and then the pedal was stuck so we took the master out and the fork was stuck against the wall of the bellhousing so we pried it out and put it back in place. Put the master back in and it worked fine. And i drove it home.
P.S. We never blead anything yet cause we were pretty tired and frustrated. Took us about 6 hours to do the install. Hopefully this week we will do that.
Old 05-20-2007, 03:00 PM
brad8266's Avatar
The PP bolts should be in the area of 50-55 lbs and the flywheel to crank bolts 70-75 lbs. Well thats the tq specs on the ls1, I guess the Lt1 is close too.
Better bleed it asap.
Old 05-20-2007, 04:47 PM
ya i will bleed it tomorrow after i install the new thermostat. But wow that is alot of torque, the thread on the bolts were damaged just after 40ft lbs. But i can't see that causing this sound.
Quick Reply: spec 3 clutch and flywheel install
