Going to try a little camshaft experiment..
Since the big/small FI cam debate always seems to end in a stalemate or dyno numbers I figured since I was a little bored I'd step up my cam by around 10 degres @ .050 and see what happens. The car ispretty consistant and I will be able to tell right away whats going on after a couple passes.
Old cam was a 222/228 comp XE, .550 lift, 115LSA
New cam is one of EPPs FI cams, 232/240 XER lobes, .600 lift, 115LSA
Duration ar .006 isnt as large of a spread, 275/281 old cam to 281/289 due to the quicker XER lobes.
Hoping to finally take advantage of my big exhaust and the AFR 225 heads and be able to take advantage of the F1A as well and hopefully not lose too much on the 60 foot. I'm curious to see what happens, going to run it with the D1/3.7 pulley tonight. Should sound a little better then the old can anyhow, just waiting a little bit before I fire it up and wake up the neighbors
Originally Posted by Inspector12
I will suspect in your situation (Drag Racing) that you will pick up a bit. I am curious to see your results also. Good luck with the new cam.
Plus I'm starting to feel bad having a low 9 second car at the track and no panty dropping idle
Good luck KP, you are the man!!! please take some more videos, I think all of us watch them repeatadely
Oh, did you ever get the coolant issue solved?
Originally Posted by engineermike
Can you run both cams with a turbo also?
In honddar world we get really good results with larger all-motor camshafts on turbo vehicles. I was questioning whether the v8 crowd is just a whole diffrent ball game or if the old " high lift, low duration for turbo cars " is just a big myth.
Originally Posted by b18c1hybrid
Looking forward to the results. I would hit the 1/8 mile unless the Year One event has a 9.5 or quicker class.
LS1TECH Sponsor
We need to get KP a satellite dish so he can post from the track
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
