STS guys, what are you doing with radiator shroud?
Old 05-22-2007, 11:48 AM
vipvegas's Avatar
Default STS guys, what are you doing with radiator shroud?
After removing factory air box and radiator plastic support. The radiator and the metal coolant pipe lean in toward pulleys, what are you guys doing to hold these radiators back??
Old 05-22-2007, 12:29 PM
SSnakekiller's Avatar
Dont take off the plastic support. Either leave it, or replace it with a 'prettier' replacement. You can find polished ones for sale.
rksport i believe sells them?
Old 05-22-2007, 01:26 PM
RooRnZ28's Avatar
zip ties are your friend
Old 05-22-2007, 01:50 PM
smoke20's Avatar
i replaced mine with a BMR polished shroud -- nothing like a little bling-bling to the eng bay
Old 05-22-2007, 02:16 PM
trtturbo's Avatar
get a factory LT1 rad support.
Old 05-22-2007, 02:30 PM
jeffboy757's Avatar
+1 for the lt1 style
Old 05-22-2007, 02:37 PM
vipvegas's Avatar
Ill try to use the factory one, you are right I feel Married to box of zipties.
Thanks guys
Old 05-22-2007, 04:46 PM
pdanrichey's Avatar
I got the shiney metal one...I'm guessing the stock one could work though. Zip-tie the crap out of the wires and the coolant line to hold it back, or cut the rubber radiator hose about an inch+ and reconnect. I did not cut mine and it's tight...but it fit between that hose and the pullies.
Old 05-22-2007, 05:02 PM
Jake@EPP's Avatar
The BMR rs-001 is a great piece for any engine bay. Looks great and fits well.
Old 05-22-2007, 07:50 PM
2002ws-6's Avatar
+1 for lt1 support, If you get a used one and your state cares about emissions take the stickers off that have the wrong year on them, F'n smog state
Old 05-22-2007, 08:25 PM
EPP
EPP's Avatar
Smile
BMR RS001 used on this Camaro SS with an STS Turbo.
http://www.exoticperformanceplus.com...Car.php?car=32 Bob
Old 05-22-2007, 08:49 PM
LS1Tech Sponsor
Superman09's Avatar
I have one of those on the way from you Bob! Thanks for the quick drop-ship BTW. I also suggest the BMR piece, mainly because of the way it enhances the engine bay!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Quick Reply: STS guys, what are you doing with radiator shroud?
