Short throw shifter
Old 05-27-2007, 02:18 PM
wldesyWS6's Avatar
Default Short throw shifter
whats the best and/ or shortest one? pro 5.0 , ws6store, ? and im takin it that the stock **** one my WS6 (not Hurst one) will fit?
I just dont generally understand them i guess, its my first 6 speed. I just dont know why some are $25 (ws6store one i think) and some are like $125.
What would you suggest?
Thanks, Ryan
Old 05-27-2007, 02:24 PM
NHRArox's Avatar
ive never seen a short throw that was 25$, ive seen a lou's short stick, which is just the shaft that is shorted that connects to the base of the shifter, and it was like $50. I have the factory hurst and i think im going to go with a b&m ripper shifter b/c i drove one of my friends z06 with one on it. your shift **** should fit all aftermarket short throw shifters for your car.
Old 05-27-2007, 02:37 PM
teke184's Avatar
yeah the $25 ones are just the shift stick...not the shifter assembly.
they make a hell of an improvement over the crappy stock unit. so if you're on a budget...do go for it.
but an aftermarket shifter is the best way to get a realy tight shifter with shorter throws.
Old 05-27-2007, 03:13 PM
skifast87's Avatar
I have the WS6 store short stick. Next to my cutout it was single hardly the best mod i have done. later on if you want it to even be shorter you can get the pro 5.0 and the Ws6 stick together. To make it really short.
Old 05-27-2007, 03:20 PM
TheSecretFormula's Avatar
I switched from the stock shifter to the factory Hurst w/ a short stick that I got used for $35. It made a huge difference. It's no Pro 5.0 but it's a hell of a lot better than stock.
Old 05-27-2007, 03:44 PM
Ripper415's Avatar
i got the ws6store 6" stick and freaking love it. i wish i had done it sooner. there's some before and after pics of it vs my stock hurst setup on the 2nd page of my cardomain if you wanna go see.
Old 05-27-2007, 08:24 PM
wldesyWS6's Avatar
i think i might have to be spoon fed this one, lol. I dont care about $ at all, since its only gona be a hundred and some anyways. I just want the SHORTEST, TIGHTEST, MOST FIRM, EASY, BEST shifts. or whatever you want to call them. I dont care what i need to get, i just want to get the best, mess w/ it once, and be done. sounds like pro 5.0 and something.....?
Old 05-27-2007, 08:34 PM
Grifter's Avatar
A Pro 5.0 with a short stick(WS6Store or Lou's) is going to very short. That sounds like what you want, but I would suggest trying it out first if you can find someone local with it.
Old 05-27-2007, 10:26 PM
mypoorLS1's Avatar
Remember, that when you shorten the stick, you loose leverage and shift effort goes up.
Old 05-27-2007, 11:50 PM
wldesyWS6's Avatar
thank you sir, ill keep that in mind....
so let me see if i understand this all. There are actually 3 parts to my shifting system if you could call it that, that i can up grade 1. the shifter 2. the stick for the shifter and 3. the shift ****. of which i will probably want a pro 5.0 w/ a ws6store short stick?
Correct or not?
Thanks for being patient everyone....
hard to believe that i could spec out a cam, but dont know about these, just never had to worry about it w/ an A4 in the past..
Old 05-28-2007, 09:09 AM
Grifter's Avatar
Correct or not?
That is correct although most wouldn't consider the **** a big factor, eventhough it changes the feel, not of the shifts though.
By going off of what you want, you would seem to be happy with a Pro 5.0 and a short stick.
Old 05-28-2007, 09:38 AM
Switchblade's Avatar
The WS6 short stick comes in two length's 6" or 6.5". I got the 6.5" version - a big improvement over the OEM stick, and I'm still am running the stock oem shifter (Hurst). Definitely a must have mod. My only regret was that I didn't do it sooner.
Old 05-28-2007, 10:17 AM
skifast87's Avatar
Really man if your short on cash. Do the Short stick first. Then ask your self if you want it to go any shorter. thats what i did and i am still happy with my short stick
Old 05-28-2007, 10:38 AM
bmax's Avatar
Thumbs up
Get the Pro 5.0 and cut an inch off, if you want shorter, then get the short stick and bolt it on.
Pro 5.0 -1" is perfect for me.
Brad
Old 05-28-2007, 11:11 AM
WILWAXU's Avatar
Lets try this in the Manual Transmission section
Old 05-28-2007, 02:24 PM
Kalgorn's Avatar
I cut over an inch off of the Pro 5.0 stick that came with the shifter and it's perfect. Other short sticks with the Pro 5.0 shifter just don't work as well. The Pro 5.0 Power Tower is basically mounted off-center compared to the stock shifter and therefore a straight stick does not work well enough. The Pro 5.0 stick that comes in the box is angled and works perfectly with at least 1" cut off of it.
Just put the stick in a vice and use a hack saw with a fine-toothed blade. Cuts right through it. Then use a file or a grinder to bevel the edges of the threads so the shift **** goes on easier.
Old 05-28-2007, 02:33 PM
05 GSXR 1XXX's Avatar
i have a hurst in mine, i just cut the stick and welded it back, i think mine is no more than 4" then again i dont have a center console.
Old 05-28-2007, 04:37 PM
Harmon84's Avatar
I have the ws6 store short stick and for some stupid reason i cant hit 3rd gear
Old 05-28-2007, 06:20 PM
Kavslayer's Avatar
I bought a after market hurst billet shifter(was told at a later date that they were really hard on the Shift forks) and its REALLY tall. If i buy a WS6 store short stick will it bolt to the after market hurst? or should i just say fk it and cut and weld it(i work in a machine/welding shop in the army)
Old 05-29-2007, 12:09 AM
Intragration's Avatar
I've got the Pro 5.0 and Lou's Short Stick. I love it. The short stick bolts right on, and with locktite, it stays on. Third gear is not always easy to get. I have to baby it, Probably due to motor mounts, but I'm used to it. The Pro 5.0 has adjustable overtravel stops, supposedly to protect the shift forks. Some of the others may have these as well.
Quick Reply: Short throw shifter
