Just finished the C5 brake upgrade
Even though this is an "old" mod in terms of so many people already having done this. I also upgraded with front and rear Prothane sway bar bushings and end links, and painted the front spindles, sway bars, and differential with Rust Bullet.
Originally Posted by GTObsessor
Nice. How do you like your new breaks?
Originally Posted by blomeup647
Does the car stop or what?
Originally Posted by GMMillwright
Which adapter brackets did you use? UMI, Kore3, LG?
Originally Posted by Proud2bSS
I used an original set of Bob Bishop brackets I bought last year from a fellow LS1tech member. I believe the design was purchased by another company. I don't recall the name (trick.... something). This design required that I cut the lower spindle ear off.
Originally Posted by tbird31
are those corvette rear brakes also? or did you just clean up and paint the rear stock ones? i've been wondering if a full either C5 or Z06 brake swap is possible possible without spending enough money to fund a big brake swap lol.
