Help - LCA Relocation Bracket Install
Old 06-09-2007, 03:19 PM
Switchblade's Avatar
Default Help - LCA Relocation Bracket Install
I've just acquired a pair of the LCA Relocation Brackets from BMR - bolt in type and had an issue during the installation that I need help.
The car is an 02 Z28 M6 equipped with ABS and ASR.
The issue I'm having involves the brake retainer bracket the holds the parking brake cable and the brake lines feeding to the rear calipers. This bracket also wraps around the OEM LCA mount and is secured with a bolt that also holds the LCA in place. Please advise if you guys either had to bend the retainer bracket to get the relocation brackets in place or was a section of this retainer bracket cut-off and discarded.
Thanks
Old 06-09-2007, 07:10 PM
2_wacko's Avatar
I bent mine, but not cut them off yet. Let me take a quick pic to show you what it looks like.
Old 06-09-2007, 07:13 PM
2_wacko's Avatar
Heres a quick pic.
Old 06-09-2007, 07:31 PM
I see so that part of the retainer bracket will not be used when the relocation brackets are installed so the option is there to cut a section of it off or bend it like in the above pic.
Thanks for the help.
Old 06-09-2007, 07:35 PM
2_wacko's Avatar
Most cut that part of it off.
Old 06-10-2007, 11:35 AM
CAMJAG's Avatar
Cut it off
Old 06-10-2007, 11:39 AM
chupr0kabra's Avatar
Agreed. I cut mine off too, just like BMR's instructions said I should...
(hint hint)
-Mike
Old 06-11-2007, 09:03 AM
Crash00527's Avatar
i just bent mine out and said f*** that lol im gonna cut it off next chance i get.
Quick Reply: Help - LCA Relocation Bracket Install
