Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Oil pressure sending unit....
Old 06-12-2007, 12:26 AM
That's what she said...
TheBlurLS1's Avatar
Default Oil pressure sending unit....
My neighbor (2002 c5) asked me if I wanted to replace his oil pressure sending unit, told me his guage pegged out one day and has been there for a few weeks. I removed the manifold etc., and noticed the sensor is different than the F-body.
When I removed the sensor I noticed there was oil coming through into the actual electrical plug area, figured the sensor just cracked or something. I cleaned out the plug of oil, put the new sensor in, plugged it up, everything was golden and working perfectly.
Week later he tells me it's doing the same thing again. Anyone have any experience with this? Is there something I don't know about the 'vette sending units? I used to a TQ wrench and installed the new sensor using the proper socket (sending unit socket) and to the correct TQ spec, not sure what's going on.
Thanks guys.
Old 06-12-2007, 12:28 AM
TheBlurLS1's Avatar
The Corvette's only mods are K&N intake kit (FIPK I guess), HPP3 (not my idea), and a NOS brand plate system (125hp).
Old 06-12-2007, 09:17 AM
Tony @ MPH's Avatar
C5 oil pressure sending units are notorious for going bad. Some of them just like you described (replaced it, worked fine, then went bad again). Fortunately I have had 3 C5s, none of which have had that problem (ever).
Some guys have gone as far as relocating the sender so it's easier to swap.
http://forums.corvetteforum.com/show....php?t=1588172
Old 06-12-2007, 11:33 AM
LostCauseZ06's Avatar
mines gone out 3 times, i gave up and just said to hell with it lol
Old 06-12-2007, 10:26 PM
99-FLvette's Avatar
Mine has gone out once but a friend of mine went thru 3 in 2 months. The sensor appears to be of less than great quality.
Old 06-13-2007, 05:40 AM
TheBlurLS1's Avatar
Well at least I know what the problem is now.
I think we're just going to say screw it. He's got a warranty on the car for another couple of years, so if anything screws up, we'll just take the kit off of it and reload the stock tune.
Old 06-13-2007, 11:17 PM
Tony @ MPH's Avatar
If it still has an OEM warranty I'd just take it to the dealership for a replacement. There's no way anybody would ever tell him the OP sending unit is broken due to the mods he has installed (especially with how frequently they die on their own!)
BTW some people have had better luck with one brand/type of sending unit than another. I've never had the problem so I never researched it deeply but I remember reading it on Corvette Forum a while back.
Old 06-14-2007, 06:09 AM
TheBlurLS1's Avatar
I don't think he wants to risk bringing it in with the nitrous installed and getting red flagged or something. He doesn't mind giving me $100 to yank the manifold each time (only takes a few minutes), so I may try throwing another one on after I tell him about this.
I'll do a little reading on it over on CF. Thanks for the info Tony!
Old 06-14-2007, 10:04 AM
Todd157k's Avatar
My addition to that thread is on page 4 (I think) and it shows how to access the sending unit without removing the intake and without all the extra parts to relocate.
Old 06-17-2007, 08:53 AM
2MuchRiceMakesMeSick's Avatar
100 to remove the manifold...your really sticking it to him, where can I get some neighbors like that
Old 06-18-2007, 01:45 AM
VETTEX2's Avatar
http://corvettemechanic.com/forum/showthread.php?t=911
everything you need to know is here
cut the fiberglass
Old 06-18-2007, 05:23 AM
TheBlurLS1's Avatar
That's called "a Corvette owner".
I tried to tell him I'd do it for $50, but he'd have none of that.
Thanks for all the help guys.
Quick Reply: Oil pressure sending unit....
