Need help putting on SLP UD PULLEY.....
Old 06-14-2007, 04:39 PM
LT1Formula007's Avatar
Default Need help putting on SLP UD PULLEY.....
My brother just bought an SLP UD Pulley for his 98 Trans Am and we got the old balancer off but we can't find an installer to put the UD Pulley on with. I was just wondering if anyone knows what i need to do to get the damn UD Pulley back on his car. ( Forgot to mention no Hardware store sells a longer bolt with the same thread size to put it on with...) And part stores don't know what the hell to give me, i've tried all kinds of ****. PLEASE HELP!!!! Thanks in advance for any advice Also if you could include part #'s or where to get the install tool at that would help.
Old 06-14-2007, 04:42 PM
bad6as's Avatar
the install tool is a longer bolt.
Old 06-14-2007, 04:43 PM
Do you know where I can get the longer bolt?
Old 06-14-2007, 04:45 PM
bad6as's Avatar
some of the guys on here sell/ rent them to other members, just search for install tool
Old 06-14-2007, 05:18 PM
Mssingkid's Avatar
Yes get the install too. The idea here is to "PUSH" the pulley on, and not pull it on to the snout of the crank. If you pull it on, you run the risk of damaging the threads...
Old 06-14-2007, 05:29 PM
I still have no clue as far as where to get the bolt to do the install with. I can't find a bolt anywhere at all. Any suggestions? Or if anyone lives in Indianapolis He'll pay for the help or to use the tool. We need it done tomorrow or we may end up having to take it to the dealer and that sucks. They want like $100 - $200 to install the new pulley.
Old 06-14-2007, 05:46 PM
Mssingkid's Avatar
https://ls1tech.com/forums/removed-locked-thread-graveyard/391883-new-crank-dampener-installation-tool-pics.html
See if they can overnight it to ya. When your done, sell it on the board and make some of your cash back.
Old 06-14-2007, 06:30 PM
SSDriver's Avatar
I got my pulley started with a block of wood and and BFH hammer. Just put a piece of wood across the front of the pulley and tap the pulley until it starts. You will NOT damage the pulley and it will eventually start. then you can just use your stock bolt to seat it all the way. Pull the stock bolt out and put in your NEW crank bolt and torque it down.
-william
Old 06-14-2007, 10:23 PM
618HAWK's Avatar
Originally Posted by Mssingkid
https://ls1tech.com/forums/showthread.php?t=391883
Thanks Missingkid----
If only it was not so close to the weekend. Can have one to you monday morning via Fed-X. If needed..............Hit me with a PM if I can help.
Chris
Old 06-14-2007, 10:31 PM
Thanks to everyone for the help..... We'll see what happens in the next few days. I'd like to have it done tommorow or saturday.....Wish me luck!
Old 06-14-2007, 10:38 PM
white_camaro's Avatar
ive put on a few pulleys by using a longer bolt but be careful. i have heard several horror stories about bolts being broken off in cranks and stripped threads.
Old 06-14-2007, 10:41 PM
waterbug1999's Avatar
-william
Thats what I did with my powerbond UD pulley I got from TSP...
Old 06-14-2007, 11:08 PM
Mike94ZLT1's Avatar
Holy **** DO NOT use a longer bolt... I had one break off in my crank earlier this week, and then had an easy out break off in the bolt. LUCKILY the engine was out of the car, but the only place that could get it out was a place that did EDM and it cost me $220 to get it fixed. Use the right tool, or don't do it, its not worth the risk. Please learn from my mistake.
Old 06-15-2007, 03:43 PM
thanks for the input everyone, I'm probably gonna get the tool from 618hawk. The tool he makes looks very solid and well put together, so if I need anymore help I'll let evryone know. By the way I don't know what the hell I'd do without the help from everyone on LS1Tech... you guys rock! 618Hawk I got the PM, and will contact you again.
Old 06-21-2007, 04:48 PM
cals400ex's Avatar
can the pulley be removed with the radiator in place?
Old 06-21-2007, 04:55 PM
mike s.'s Avatar
Hard to do with out taking it out.........here is a good writeup of a cam change howto, removing and reinstalling the harmonic balancer is part of it.
http://www.ls1howto.com/index.php?article=23
Old 06-21-2007, 06:34 PM
sunsetta's Avatar
Miike 94z, you did not use the correct bolt. It MUST be a Grade 8 hardened bolt, and you Must get the pulley started straight.
