Torque arm question
Old 07-02-2007, 04:38 PM
renxwar's Avatar
Default Torque arm question
Well, I just ripped the torque arm off my tranny, so looks like I'm in the market for a crossmember-mounted torque arm. I've got my eye on the Spohn one, but I've run into a problem.
They offer two versions, one for shorty headers, one for long tubes. I have stock manifolds, but plan on putting some ARH long tubes on fairly soon. Do the long-tube version torque arms just have extra clearance, or will it not fit with my exhaust in its current state?
Thanks in advance.
Old 07-02-2007, 04:54 PM
UMI Performance's Avatar
Hello,
The long tube versions just have addtional clearance for the y-pipe. I don't I have ever heard of ARH so I can't comment on there set-up. But some long tube set-ups will clear with the torque arms design for stock manifolds, it all depends how well the y-pipe tucks up. If you take a look at the links below you will see the items are almost identical but the one in the lowest link has a drop down built in for y-pipe clearance.
www.umiperformance.com/2201
www.umiperformance.com/2203
If I can help any I am glad too.
Ryan
Old 07-02-2007, 05:45 PM
renxwar's Avatar
American Racing Headers = ARH. So, the long tube version will fit a stock manifold/ypipe setup?
Old 07-02-2007, 06:02 PM
Yes and No. The drive shaft loop built in will not clear the stock y-pipe with out unbolting the Y and moving it around, then it *may* clear. If you get the long tube version with out a drive shaft loop it will clear virtually any set-up.
Hope that helps,
Ryan
Old 07-02-2007, 06:08 PM
renxwar's Avatar
Alright, one last question before I pull the trigger and pick one of yours up.. is the chrome moly (if thats spelled right) version worth it? Whats its advantages, compared to steel?
Old 07-02-2007, 07:54 PM
super_fro_daddy's Avatar
Old 07-03-2007, 02:13 AM
WolfgangX's Avatar
weight is most of the advantage of chrome moly, it is a little stronger but it's not like you're running 1000 hp on slicks
Old 07-03-2007, 09:50 AM
renxwar's Avatar
Thanks for the help Ryan, I just picked up a long tube, non-ds loop torque arm and 3 point weld in SFCs from you guys.
Old 07-03-2007, 10:07 PM
Glad to help and thanks for the order! You will be very pleased with this set-up
Quick Reply: Torque arm question
