sealed hood
Old 07-08-2007, 12:05 PM
Disturbed Bird's Avatar
Default sealed hood
does anyone have a write up to how to seal a ramair t/a hood?
Old 07-08-2007, 03:17 PM
jag42420's Avatar
I have yet to find a write up, but what most do is debaffle the rear baffle (by drilling out the rivets) and leave the front. Then get some weatherstripping at a local home improvement store and some adhesive at an auto parts store and glue the weatherstripping to the hood. You can hear the difference from the front of the car where the intake is afterward. Cooler air = more power...
Old 07-08-2007, 03:23 PM
jag42420's Avatar
Unfortunately, the BGRA kit http://www.geocities.com/brian98rama..._Air_Pics.html isn't made anymore, but you can see the parts at that link. The weatherstripping needs to be about an inch thick to seal well between the hood and the airbox.
Old 07-08-2007, 03:27 PM
02TransAm/Batmobile's Avatar
Do a search for Patrick G's homepage. It's on there.
Old 07-08-2007, 03:44 PM
jag42420's Avatar
Cool deal. http://guerragroup.com/2000TA.htm I've been considering trying to make something from fiberglass, with inserts and a spacer. I used concrete expansion joint material (foam board) to make what I'm using now...
Old 07-08-2007, 06:03 PM
2000TransAmWS6's Avatar
does anybody know what Patrick used to make his spacer?
Old 07-08-2007, 06:09 PM
ThaBirdMan's Avatar
If the search wasnt down you could fiqure out.
Old 07-08-2007, 06:17 PM
01pewterbird's Avatar
https://ls1tech.com/forums/showthrea...08#post6693308
Check out the last pages in that thread. Made a box within the hood to ensure the air has a straight smooth path to the filter.
Old 07-09-2007, 01:59 PM
yes, and if a frog had wings he wouldn't bump his *** when he hopped
good thread 01pewterbird!
