Car cranks, wont start.
Old 07-11-2007, 02:38 PM
Stangkilr's Avatar
Default Car cranks, wont start.
This has been going on off and on for a couple week. Now it just will not start at all. It will crank but not fire, fuel pump is kicking on everything seems normal. Any suggestions?
Old 07-11-2007, 02:50 PM
slvrhwk's Avatar
Check the Ignition Relay.
Old 07-12-2007, 12:18 AM
GOaT Cheese's Avatar
what's the security light doing? Is it blinking, staying on solid, or does it go out after a few seconds with the key in th "on" position?
Old 07-12-2007, 12:22 AM
Stangkilr's Avatar
It goes out after the key is on. While I have the heads and cam out im going to replace the crank and cam sensors hoping that fixes the problem.
Old 07-25-2007, 05:50 PM
Stangkilr's Avatar
Still wont start. Put a new ign relay in didnt do a damn thing.
Old 07-25-2007, 07:58 PM
chavez885's Avatar
have battery and alternator tested already?
Old 07-26-2007, 05:59 AM
frisky2101's Avatar
I had a sim problem the other day, thought car ran out of gas but it didn't.
Car would crank but would not start, fuel pump was priming and had plenty on fuel getting to the rail.....
You can try and look for a yellow with black stripe wire that comes off the PCM to the stater then to the coils, it'll be in about a 1inch thick loom with heat wrap running on the passenger side of the car between the frame and the header/manifold.
Mine some how ended up touching the header and melting the loom and completely fired the wire, cut out the bad section and spliced in a new piece and made sure it was well out of the way of the header and after that it cranked right up
hope it helps
Old 07-26-2007, 06:08 AM
Black FormulaLs1's Avatar
let us know if this worked for you and maby some pics wouldnt hurt either
Old 07-27-2007, 04:50 PM
Stangkilr's Avatar
I had a pinched fuel line. Started right up after I fixed it.
