Car Sways in the back
I have BMR non-adjustable LCA’s and PHB. The car feels like it has a slight sway in the rear at highway speeds. (65+ MPH) The rest of the suspension is factory. If you have ever driven a small pick-up with a heavy load in the back, that is about what it feels like. Thanks for any input.
Pressure is good in the tires and they are Nitto 275/40's. Definetly not the tires. I'll check the other stuff, thanks.
Moderator
Well, I know with my 285/40 GS-D3s they get all squirmy like
that if I run at 30PSI, but tighten up nicely at 34PSI (which
is more than recommended). "Good" is a sliding scale.
Originally Posted by Black 99 Bird
Pressure is good in the tires and they are Nitto 275/40's. Definetly not the tires. I'll check the other stiff, thanks.
a little more psi may help, but with a well damped rear end, good lca bushings and positive sway bar function 32/29psi in a good tire is also recommended. Make sure your panhard bar is in good shape.
yes, bigger sways and new bilstein HD shocks were my first two mods and they fixed the icky feeling in the back.
You probably would want to get third gen. rear bilstein shocks as they are valved better.
