boost guage vacuum source
Old 07-17-2007, 05:59 PM
02NBMFormula's Avatar
Default boost guage vacuum source
im in the middle of installing a boost gauge on my bird and tried searching but havent found a pic of where to tap in to a vacuum line. i know that the brake booster is an option but id rather not have to run to the store to get the right t fitting. ive read there is a vacuum source between the hvac and the engine on the passenger side but cant find that line. also is it possible to use the fitting that came with the autometer guage (mechanical)?? pics are greatly appreciated
Old 07-17-2007, 07:04 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
https://ls1tech.com/forums/forced-induction/627348-vacuum-lines-gauge-install-help-newbs.html
dont be lazy,do it right.
Old 07-17-2007, 09:09 PM
so re-do all the vacuum lines??? theres got to be another way.
Old 07-17-2007, 09:42 PM
ddnspider's Avatar
who said redo all the lines?how is your vacuum stuff setup now?
Old 07-18-2007, 10:15 AM
i thought that you redid the factor vacuum lines, my bad. my lines are set up just as it rolled out of the factory.
the big black tube is the brake booster, correct?
did you make a "T" fitting or what? thanks man, i appreciate it
Old 07-18-2007, 04:37 PM
ddnspider's Avatar
i redid my PCV lines which is another story.my vacuum lines are stock.i T'd the brake booster line for 1 source and T'd off that for the others.my boost gauge connects on the passenger side of the intake as you cant use the stock PCV with no checkvalve as it will pressureize the crankcase.i just took off the line goes from each valve cover and connects to the pass side of the intake and ran both valve covers to a catch can and then to the inlet on the turbo and used the port of the pass side of the intake for my boost/vacuum gauge
Old 07-18-2007, 05:43 PM
gotcha man. i just got it working with a T fitting on the brake booster. thanks dude.
Old 07-18-2007, 09:13 PM
Texas Heat's Avatar
.........nevermind...........
Quick Reply: boost guage vacuum source
