f.a.s.t , ls6, or stock intake on a supercharged ls1?
i have a procharged ls1 in my 79 c10. which intake do you think would help me the most, a f.a.s.t, ls6 or a stock intake. i have access to all three. i have heard different opinions where i live, so i thought id ask you guys (and girls).
I'd stick with the LS6 intake. This C5 is making 740 rwhp with the LS6 intake, stock maf and stock throttle body.
http://www.exoticperformanceplus.com...Car.php?car=40 Bob
If you want to use the FAST it can have good results but I'm not sure it's limitations on boost. I'm at 13psi with no problems. Just make sure before you install it you take it apart and use some strong silicone between the two sections. That helps to make it stronger and prevents any chance of it leaking boost.
what would be an example of a good aluminum intake manifold? I have been wondering the same thing. I currently have an ls6 intake mani and I am looking to turbo soon @ around 15psi...
Originally Posted by PHIL H
Keep your LS6 manifold...Ohio Boys ran low 8's and made 1400+hp with a LS6...Dont waste your $$ on anything else.
Fast is not worth the money stick with the ls6 or go sheetmetal.
Sheetmetal > FAST > LS6 > LS1
There, I made it easy. And as would be expected, cost flows in the same pattern. You want to make the most power? Go all the way to the left. But that's also where you'll be spending the most money.
