Remove metal exhaust shields under car?
Pulled mine off because they rattled like a sumbitch...no problems with headers, off-road y-pipe, and Hooker cat-back. I did paint the y-pipe with ceramic paint to help keep the temps down and the heades are also Jet-Hot coated.
JC
JC
They're not only heat shields, they protect your fuel lines and wiring from debris and foreign objects.
Something flies up at speed, damages a fuel line, and you leak fuel on your red-hot LT header, well, you can guess what happens next can't you?
Some people post some retarded things to do.
I wouldn't remove them, they're functional and they weigh very little. When I did my header install, I noticed that the sheilds on the passenger side rattled a little. I drilled a couple holes and riveted them together.
