Western Members CA, AZ, NV, UT, CO, NM, HI
cam question for CA emissions
Old 07-24-2007, 12:34 AM
runningman's Avatar
Default cam question for CA emissions
Does anyone know if a 228/232-deg. 115-deg LSA will pass CA emissions?
thanks
Old 07-24-2007, 02:46 AM
BayAreaSS's Avatar
I highly doubt it but i'll let someone else chime in.
Old 07-24-2007, 08:14 AM
BigDaddyBry's Avatar
Overlap is good but don't know if that duration will kill it. I'm sure all anyone can do is speculate.
I'm thinking you'd want more negative overlap with a cam that size.
Old 07-24-2007, 09:34 AM
Formulated's Avatar
I've got a 228/228 114LSA to put in my '02, and I plan to use Rhoads lifters to get through the smog check. These lifters should shorten up the duration in the rev area of the smog test and get me through.
What do you have for an exhaust system?
Old 07-24-2007, 02:58 PM
SnakesRslow's Avatar
thanks
search for flash99's post a few months back about passing ca emmisions. although i do believe it was in a 6.0 goat, if i remember correctly, he had the same duration but on a 114lsa and passed, but barely.
If your tryin to pass smog still is that extra bit o duration really worth risking possibly having to pull the cam out at a later date? My theory is either keep it safe or go huge.. just my .02
Old 07-24-2007, 03:35 PM
BayAreaSS's Avatar
Good theory. I think i'm going to just man up and get a cam that cant pass smog and try to work that out later.
Old 07-24-2007, 03:48 PM
SOM 02's Avatar
if you get a small cam rightnow you will probably regret not getting a big cam l8r. to pass smog you just gotta pay alittle xtra
Old 07-24-2007, 04:03 PM
Almostryan3's Avatar
flash has a escalade block, like 416 or something iron block with the texas giant cam... slow car really for what it is...
Old 07-24-2007, 05:02 PM
im not talking about the new motor he's got. notice where i said a few months ago
and you talk way too much **** for as stock as you are
Old 07-24-2007, 05:38 PM
ReFtheMC's Avatar
AHHAHAHA...
Old 07-24-2007, 07:57 PM
KWIK WS6's Avatar
Old 07-24-2007, 08:02 PM
418 motor huuuge cam full bolt ons gutted full slicks and skinnies gears and a 'turbo' and only going 7.60s...... that is pathetic, i can talk all the **** i want, not my fault their cars are under performing. My car is going as fast as soo many other cars, HC cars rear mount cars ect ect, its ******* lid muffler gear. So apparently stock kicks ***
Old 07-24-2007, 08:16 PM
BayAreaSS's Avatar
Yea we talked about this before. I'll be paying a little extra because i want something bigger than a 224.
How's the 408 coming?
Old 07-24-2007, 08:21 PM
BayAreaSS's Avatar
You do get out of hand somtimes with talking **** about other people's cars.
Old 07-24-2007, 10:11 PM
I'm not standing up for someone who can't fight 'cause I'm sure he can defend himself, but sometimes you overstep yourself.
Check it before you wreck it.
Old 07-24-2007, 10:17 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
hmm.... he doesnt have a texas giant cam, its my custom grind cam its similar to a texas giant but it is not a texas giant. you run flash in quarter, and see how far ahead he is........ mind you he does have alot more power then you, but that is what happens when you have alot more power, you will out mph a certian opponent, but not necessary out et them. any time you want run my jeep let me know .......... we will see how cocky you are after losing to a suv
p.s. he went 7.60's on the motor.
Old 07-24-2007, 10:41 PM
Ok well I apologize, he told me it was the texas giant cam. And I know there are plenty of faster cars, but when he has that much into and is only running that its pretty sad. and I am not cocky I know there are alot of faster cars, fact is their are alot of cars with waaay more going same speed or slower and I can say they are under performing because the bottom line is, they are. Hell I know a camaro with the same as what I have done to mine (different lid and exhaust) he has a 3k stall and stock gears full weight AC and everything going 12.0. No LTs stock manifolds and all. Fact is there are plenty of cars out there that are under performing, if pointing them out makes people upset, oh well, little motivation for em.
PS he went 7.60s on the turbo at best every time I saw him
SOM 02's Avatar
my motor and trans is out of the car. gonna start switching stuff over to the new motor this weekend
And another thing, you talk about "under-performing"... you really are bench racing even if you have an over-performing stock internal car.
Apples to ******* oranges...
Old 07-24-2007, 10:42 PM
yeah, they can be running faster but for some reason are not, thats under performing.... and no mine is a normal performing car for what it is, nothing special...
Quick Reply: cam question for CA emissions
