Are the spark plug wire metal sleeves necessary?
a lot of people use them for msd wire because most but not all hit the header. As long as the wire is not directly up against the header you should be able to do without them.
My first set of MSD's cooked on the header. Didnt read the box enough to figure out they could be bent. My second set I bent 2 that touched a have an easy 1/4 inch at the closest. thats plug boot to header. Thats plenty of room. I had a misfire in cyl 6 which the plug boot was fine. My #4 was cooked but didnt miss. And my misfire only showed up when I mistakingly put the pass side o2 sim in the primary spot.
Pontiacerator
Originally Posted by SpdFrk1990
Heres mines they dont look bad to me?? Why not reuse them?
