Any Better Brakes Than Wilwoods For A 17 Inch Rim
Old 07-25-2007, 09:25 PM
Jpr5690's Avatar
Default Any Better Brakes Than Wilwoods For A 17 Inch Rim
I Have 17 Inch Rims And Dont Wanna Go Up In Rim Size ..
This Being Said Is There Any Better Brake Packages Than The Ones Wilwood Offer For A 17 Inch Rim
I Think The Wilwood Package Is Their Superlight 6piston Calipers And A 13 Inch 2 Piece Rotor
Old 07-25-2007, 09:42 PM
wannafbody's Avatar
my friend uses Wilwoods on his 3000 horsepower funny car- they should work fine on a fbody as would SSBC's
Old 07-26-2007, 04:27 PM
gun5l1ng3r's Avatar
Both Wilwoods and SSBC's, in my opinion are not even a great braking option. Are they better than stock? Yes. Are they worth the money? No. For the same price as a Wilwood setup you can get a MovIt Porsche caliper setup. With those calipers and brackets, you have the option of running MANY differnt types of rotors and a HUGE selection of pads as well. They are very serious brakes that probably won't start working until they warm up a little.
MovIt is based in Germany I think and they have even done conversions for some 2500HD Duramaxes.
Old 07-26-2007, 04:31 PM
GR33N GoblinM6's Avatar
stoptech's 4 piston system is awesome.. i would get this if i had $2k
Old 07-26-2007, 08:34 PM
Jpr5690's Avatar
again guys 17 inch rim requirment.. if you have systems the fit under a 17 inch rim the please by all means post some info up im definately intrested
Old 07-28-2007, 11:42 AM
i just told you.. STOPTECH.. fits under 17's
Old 07-28-2007, 11:46 AM
Jpr5690's Avatar
COULD YOU SEND ME A LINK TO THEIR KIT THAT WILL FIT PLEASE
Old 07-28-2007, 04:12 PM
www.stoptech.com..
go into their website, scroll down to "technical data" from there go to "wheel fitment" it will open up and scroll down to "Chevrolet".. select "Camaro front will upgrade" it will open a PDF fitment page.. you can print that out.. cut out the templet and measure it on your wheels.. ive already done it on the camaro SS ZR1 17x9.5 wheels and they fit.. and if you're too lazy.. here is the link
http://www.stoptech.com/tech_info/ch...83-2450-01.pdf
Quick Reply: Any Better Brakes Than Wilwoods For A 17 Inch Rim
