DIY exhaust cutout?
Old 07-28-2007, 03:09 PM
spec_j's Avatar
Default DIY exhaust cutout?
is there a way to make a flang that you can open and close on a cutout. I see no point in spending $150+ on one if i can make it. Thanks
Old 07-28-2007, 04:26 PM
Fb0dy0nly's Avatar
sure if you can make something similar to a throttle body opening, weld/bolt it all up and then attach a small motor to it so it can operate the flange, sounds like a breeeze to me....
I think this would be hard but seeing some of the other creations that have come out of LS1tech, you may never know....
Old 07-29-2007, 01:11 AM
snake charmer's Avatar
it would have to be heavy duty due to the flow . manual or electric is traditional .
Old 07-31-2007, 10:56 PM
trans99am's Avatar
ya i was thinking about just using a throttle body. dont know how ghetto it is going to look though
Old 08-01-2007, 05:53 AM
IHeartTurbo's Avatar
On one of the 1g DSM's I had, I used an old stock throttle body to make a cutout. Filled all the holes with jb weld, cut a flange to mount it to to go on the y-pipe I had made to put in place of the cat. Then just cut a hole in the floor for a choke cable I got at a lawn & garden store. It worked very well actually.
Old 08-01-2007, 06:10 AM
Fb0dy0nly's Avatar
I knew someone would have made one of these. Id like to see some pictures of that, it sounds very interesting.
Old 08-01-2007, 08:02 AM
I never took any pictures when I made it, but I still have the car sitting (I use it as storage for parts for my s13 now) so I might be able to crawl underneath it this weekend and get some pics.
Old 08-28-2007, 11:56 PM
spec_j's Avatar
hmm interesting stuff, thanks
Old 08-29-2007, 07:46 AM
Order 66's Avatar
Are you serious? If you dont wanna spend $150 then just crawl under your car and manually uncap it. It would cost you more than $150 in parts if you think you can make one last and seal up. A throttle body is not a good idea when it does not seal all the way around. If it did cars would not idle.
Old 08-31-2007, 03:52 PM
Pharcyde50's Avatar
Just drop the $30 on a cut out and weld it in.
Old 08-31-2007, 04:58 PM
JonB's Avatar
They do make such a thing for $50 the only downfall is they only come in a 2in diameter. If they came bigger like 3in I would have one but I have looked before and all I can find is a 2in.
Quick Reply: DIY exhaust cutout?
