Torque arm will not fit.
Old 08-01-2007, 12:09 AM
QuickSilver's Avatar
Default Torque arm will not fit.
God damn QTP y-pipe. What Y will fit with a UMI tunnel mount?
Will a kooks y-pipe fit QTP headers?
TIA
Josh
Old 08-01-2007, 07:21 AM
Specialized's Avatar
TSP Y will fit the QTP headers..
Old 08-01-2007, 07:29 AM
thanks it looks like i will be ordering one up.
Anyone know if the Hooker Y will fit? I can drive to Summit and Pick one up. its only 15 min away.
Josh
Old 08-01-2007, 12:38 PM
Andros's Avatar
I had no issues installing my UMI TQ Arm with my QTP Catted Y
Old 08-01-2007, 12:54 PM
Tunnel mount or trans mounted? and with or without DS loop?
If mine was W/o loop it may fit.
Josh
Old 08-01-2007, 02:37 PM
UMI Performance's Avatar
TIA
Josh
Josh,
Just about any y-pipe but the QTP will fit. But I am not sure which y-pipes will fit the QTP headers.
Hope that helps,
Ryan
Old 08-01-2007, 07:26 PM
Originally Posted by UMI Performance
Josh,
Hope that helps,
Ryan
Thanks for the reply. THe TA is a great part just need to get in.
I should just say screw it and run open headers.
Josh
Old 08-02-2007, 01:22 PM
DanWS6's Avatar
I regret buying that damn QTP y-pipe. I want to go with the UMI chassis mounted torque arm and drive shaft loop but what's the point if I can't get it to fit. Is it the collector itself that is in the way?
I'm almost tempted to ditch the y pipe and go with true duals.
Old 08-02-2007, 02:56 PM
the collector is the big part in the way but mostly its just the whole damn thing
Old 08-02-2007, 04:06 PM
DanWS6's Avatar
Can you other any specifics/pics? My y-pipe isn't really a normal one anymore since I cut the craptastic cats out since one blew out a month after putting the system in. I always just assumed it was just the collector part that got in the way.
