Daily driver cam?
Old 08-02-2007, 06:49 AM
playboy245's Avatar
Default Daily driver cam?
im thinking of getting this cam 250/258@50 580/580 lsa108 for my 416ci motor would you consider that a daily drivable cam, why or why not?
Old 08-02-2007, 06:58 AM
z28poweredlt1's Avatar
Magic Stick V.3 237/242 .603/.609"
Is what I'm running in a DD car, tune should be next week as the car is at the exhaust shop, ticket for being to loud...
Stock disp this set up is making 450 to the wheels all over the board (with a set of heads), not sure what the specs or how they would help/hurt a 416cid motor.. I can tell you this cam doesn't make any low end though... Mid range is only barely there.
Old 08-02-2007, 07:35 AM
WKMCD's Avatar
Originally Posted by playboy245
im thinking of getting this cam 250/258@50 580/585 lsa108 for my 416ci motor would you consider that a daily drivable cam, why or why not?
That's a pretyt big cam for a DD. You didn't say want heads you are running. That will make a huge difference.
Old 08-02-2007, 08:56 AM
edcmat-l1's Avatar
Thats a bunch of duration and overlap, for not much lift. Why so small on the lift? Why so much overlap? Probably be miserable to drive.
Old 08-02-2007, 09:27 AM
playboy245's Avatar
im gonna be running the L76 intake and head package from SDPc
Old 08-02-2007, 09:33 AM
playboy245's Avatar
i had the whole package thrown together from sdpc and they said it will deffinqatley perform well. im sorry guys i mis typed the cam numbers they are 250/258@50 580/580 108 LSA, i dont know too much about cams i hope that makes a difference.
Old 08-02-2007, 09:38 AM
edcmat-l1's Avatar
Might wanna talk to WKMCD and Richard over at WCCH on the cam specs.
L76 heads, or L92 heads?
Old 08-02-2007, 09:54 AM
WKMCD's Avatar
Lots of good info in this thread on a strong daily driver type 403/L92/L76 build. You may be surprised by the final cam size.
https://ls1tech.com/forums/generation-iv-internal-engine/662314-l92-dynojet-numbers-plus-plan-b-c-d-e-f.html
Old 08-02-2007, 01:28 PM
playboy245's Avatar
im running the L92 heads with the L76 intake, im planning on putting this combo into my 99z26 6speed camaro
Old 08-03-2007, 12:40 AM
Just got back from the Dyno shop, tuned 459.6hp 414tq to the ground. Daily driven.
Quick Reply: Daily driver cam?
