What do you guys think of this cam?
I bought this cam and Im having it installed what do you guys think of these specs? I know its not an MS4 or TREX cam but, I think it should still make some good power.(I hope)
Basic Operating RPM Range: 2,500-6,500
Intake Duration at 050 inch Lift: 228
Exhaust Duration at 050 inch Lift: 230
Duration at 050 inch Lift: 228 int./230 exh.
Advertised Intake Duration: 344
Advertised Exhaust Duration: 344
Advertised Duration: 344 int./344 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.585 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.585 in.
Valve Lift with Factory Rocker Arm Ratio: 0.585 int./0.585 exh. lift
Lobe Separation (degrees): 112
Originally Posted by JPH
look for strong mid-upper rpm trq, and 410+hp with those heads and cam profile. cam specs look right for your combo though. just curios on ICL? i'm guessing it's 108.
Just so everyone knows this is a trick flow stage 3 cam, that Im using.
Originally Posted by 68birdls1
That cam seems like it is close to the comp cam that I am going with. I have researched it and it seems like a really nice cam, pretty good power all around.
Originally Posted by allthrotle
Yep, Jackpot, thats exactly what it is. Its at the shop now, Ill keep you guys posted on the numbers that I make.
crane hr5 lobe stuff. cam will make good power, and awesome trq. man.
Originally Posted by 98Camarod
XER 230/230 .591? Thats what I'm getting and it should be here Monday. Unfortunately my budget doesnt allow for some nice heads, so i bought some 241's with PRC dual springs and titanium retainers off of a member.
actually no, I am going with a non XER lobe, it is the 228/230 with somewhere around .585 lift on 112 lsa. Hopefully I am gonna have it all together wed or thurs
