What radiator hoses do you guys recommend?
Old 08-04-2007, 07:26 PM
Soul TKR's Avatar
Default What radiator hoses do you guys recommend?
Long story short... the GM,Gates, and Goodyear rubber hoses are crap... the lower hose anyways...
I've had them burst, collapse, and they just really aren't made well... I'm looking for some sort of stainless steel braided non-collapsible hose mainly for the lower section...
has anyone found any substitutes for this?
I found these guys carry some, but not sure which one, if any, would fit...
Scroll down, click on "plumbing" then scroll down again and click on "radiator hose"
http://www.spectreperformance.com/#CATALOG
Old 08-04-2007, 07:42 PM
5.7 Reasons's Avatar
Interesting question. I would like to know this as as well.
Old 08-04-2007, 07:47 PM
Da Swami's Avatar
Spectre is for custom apps and show cars. You can run them, but I'm not sure about durability in a daily driven environment.
IMO they look out of place on anything but old school muscle.
Old 08-04-2007, 07:53 PM
sroach20's Avatar
i dont know about stainless but i use gates. i replace them once and never worry again.
Old 08-04-2007, 07:55 PM
BLK02TA's Avatar
Wow those spectre ones are sweet!! I like those clamps.
Old 08-04-2007, 07:57 PM
Soul TKR's Avatar
yea tried those too... same issues...
Old 08-04-2007, 07:58 PM
Soul TKR's Avatar
yea i don't really care if it's Spectre or not... they were just some I found... I'm just wanting some sort of stainless braided non-collapsing hose in place of the rubber ones...
Old 08-06-2007, 09:44 PM
Soul TKR's Avatar
bump...
Old 08-16-2007, 02:17 PM
jmdale1984's Avatar
I've gone 193k on the stock hoses. Just replaced the water pump, and they still looked in good shape. The dealer said they've got a lot of LS series truck still running at 300k with the original hoses, and not to worry about it. They don't even stock them because they never have to replace them.
I put the originals back on, and I'm not worried about them at all.
Old 08-16-2007, 03:02 PM
TA1972's Avatar
I use SAMCO silicone hoses and worked well for me with no worries.
Old 08-16-2007, 03:09 PM
MrDude_1's Avatar
well, your first post starts out as calling the highest quality hoses on the market, as crap.
then you later say you tried the gates and had the same problem
my instinct tells me, its not the hoses thats the problem, but you probably have some other issue thats causing the hoses to collapse. its highly unlikely that both your stocker, and a quality replacement failed in the same way... especially since its uncommon for these cars to have hose problems.
Old 08-16-2007, 03:23 PM
bczee's Avatar
Goodyear makes some blue Hose that are made from EPDM Rubber that is supose to last 5-10 times longer and has a burst rating 10 times stronger that normal hose.. I know that Summit cares them, but most likely if you have a good parts guys, he should be able to look them up and get them.
GM also has some Green ones that they used on the Police and services model cars.
Quick Reply: What radiator hoses do you guys recommend?
