What boost are you getting with your pulleys?
I am just curious about what boost levels others are getting with what pulley combos. Mainly D1SC and F1Rs. If you would also list the following mods:
Motor size
Heads
Camshaft
Intake system
Exhaust
Intercooler size and type
Pressure pipe size
Crank and supercharger pulley
Observed Boost @ what RPM
I have a theory on something, but I need some data to check it. All help is appreicated.
OK, here is my example
402 Iron Block
Dart 240cc TEA heads
TSP Giant Camshaft
Edelbrock SP, IntakeElbow, NW 90mm
Edelbrock Drag Race Headers & 3" Duals
Spearco A2W 3"
SDPC 7.25", 4.25 (1.81:1)
10psi @ 6000, 12psi @ 7000
Motor size
Heads
Camshaft
Intake system
Exhaust
Pressure pipe size
402 Iron Block
TSP Giant Camshaft
Spearco A2W 3"
For comparison sake here is two D1SC setups we've had in the shop lately. Both made around the same horsepower.
Note setup no2 would have made beyond 15psi with a 4.10" pulley and pushings nearly 700rwhp on a stock block Changing it to a 4.25 pulley I had brough it to 12 or so PSI.
setup no1/no2
Motor size 347 / 346
Heads AFR 225/ TSP 317 heads
Camshaft SI SC1/ TSP 232/234 112
Intake system FAST90/ Fast 90
Exhaust kooks 1 7/8 / 1 3/4?
Intercooler size and type ATI/ OBX FMIC
Pressure pipe size ? ?
Crank and supercharger pulley 3.85/4.25
Observed Boost @ what RPM 12@6200 / 12@6200
setup no1/no2
setup no1/no2
setup no1/no2
