01 M6 Z-28 doesn't have aluminum driveshaft?
Old 08-08-2007, 07:07 AM
98-LS1's Avatar
Default 01 M6 Z-28 doesn't have aluminum driveshaft?
My A4 98 had an aluminum driveshaft but after looking at my 01's it has rust on it like a regular driveshaft. I thought all 98-02 f-bodies came standard with an aluminum shaft? Am I mistaken? I noticed this yesterday while installing some LCA's on the car. Thanks!
Old 08-08-2007, 08:05 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
If I'm not mistaken all 3.23 and 3.42 geared cars had the aluminum DS. The 2.73 cars had the steel one
Old 08-08-2007, 09:14 AM
teke184's Avatar
correct....the auto 2.73 geared cars had the steel.
havn't heard whether they are as well balanced as the alum ones...or if they suck like the LT1 steels
Old 08-08-2007, 09:42 AM
98-LS1's Avatar
Why in the heck does my 3.42 M6 Z-28 have a steel one then? My 98 was a 3.23 Auto and it had an aluminum DS. I checked with the previous owner and this car has never had it replaced. Strange.
Old 08-08-2007, 09:47 AM
Jon5212's Avatar
From what I know i thought all the 01 and 02 M6's had an Alum DS, i don't know what my car's rear had stock though cause i have 4.10's now and thats the way it was when I bought it.
Old 08-08-2007, 11:31 AM
vtirocz's Avatar
The steel driveshaft could have been used under a deviation at the plant.
Old 08-08-2007, 11:34 AM
Kleeborp the Moderator™
MeentSS02's Avatar
That would be my guess...it isn't unheard of to have this happen. They probably just didn't have any aluminum driveshafts available that day, so they stuck a steel one in.
Old 08-08-2007, 05:50 PM
purdueranger's Avatar
my car has a steel DS in it but tonight it is getting a Chromoly DS from Speed Inc. This thing is a lot beefier than the stock steel one.
Old 08-08-2007, 08:27 PM
02silvaZ's Avatar
i was unaware of the "all M6's 98-02 got an aluminum DS" until recently, when i changed out my clutch i noticed it but didnt know it was standard across the board
Old 08-08-2007, 09:40 PM
Thule's Avatar
my car also has the steel one, 98 M6 car, i have wondered alot why the heck mi car was the only lsx car i had ever seen with steel unit
Old 08-08-2007, 10:35 PM
JTelesone's Avatar
i have a crappy old steel one too, o1 m6. it seems to be random....
Old 08-09-2007, 12:22 PM
ConfusedGarage's Avatar
Now its rare! Throw it on ebay next to the Jesus shaped pancakes!
Old 08-13-2007, 05:58 PM
98-LS1's Avatar
Guess we all learned something, thanks for the info! I should've swapped the aluminum one out of my 98 into my 01, oh well.
Old 08-14-2007, 11:21 AM
Mike454SS's Avatar
Maybe it's something to do with the tires the car came with? Mine's a 2000 M6 Z28 that factory had those stupid 235/55/16's on it...with a 118 mph top speed limiter in the PCM (that I turned off sunday) and a steel driveshaft underneath it.
Old 08-14-2007, 12:34 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Either it was a factory goof or a previous owner swapped it out, I tend to think it was the former, rather then latter.
Old 08-14-2007, 12:42 PM
Mr. Trick's Avatar
My 2:73 geared auto has a aluminum ds. Just one of those freak things.
Edit: Thats funny this was post number 273 for me.
Old 08-15-2007, 07:44 AM
sgarnett's Avatar
My 2001 M6 originally had the steel driveshaft, crappy 235 tires, and 118mph speed limiter (though it did get the 150 speedo). All of those deficiencies have been corrected.
The 235 Eagle GA was not Z-rated, while both of the 245 tires options (RSA and GC if I recall correctly) were.
I think that for M6 cars, only those with the Z-rated tires (and the higher speed limiter setting) got the aluminum DS.
I also think that all of the tire options for 2002 were Z-rated, so most likely all M6 cars from that year only got the aluminum DS.
Old 08-16-2007, 11:22 AM
Mike454SS's Avatar
Mine also got the 155 mph speedo...I don't think I'd have bought the car if it didn't have that.
Old 08-16-2007, 11:24 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Hell, throw the jesus shaped pancakes under the car and see how they hold up when bolted to the rear and the tailshaft. :
Old 09-13-2007, 12:57 AM
jfman's Avatar
My 98 TA a4 car had a steel shaft as well. ????
Quick Reply: 01 M6 Z-28 doesn't have aluminum driveshaft?
