TEA 5.3L heads are here, flow #'s inside
STF Veteran
Although it'll be a couple of months until I get 'em installed, they are a work of art. I have nothing but great things to say about Brian and Brent. Let me know what you all think.TEA Stage 1.5 5.3L heads milled .010 :
lift int exh
.100 69.6 53.3
.200 138.9 107.1
.300 201.8 161.2
.400 250.4 223.9
.500 284.7 254.3
.550 295.7 262.0
.600 301.5 267.3
lift int exh
.100 69.6 53.3
.200 138.9 107.1
.300 201.8 161.2
.400 250.4 223.9
.500 284.7 254.3
.550 295.7 262.0
.600 301.5 267.3
Re: TEA 5.3L heads are here, flow #'s inside
TA TED ...
Check your intake ports. Like many other 5.3 heads, TEA will port them to the point of putting a hole in the ports where the intake rocker arm bolt goes through. Mine also has these holes through the castings. No problem, but you will need to apply a liberal amount of black silicone sealant to the bolt threads prior to installing the rocker arm (intakes only).
TEA had stated that they were going to include a note about this when shipping the heads. Might want to check it out....
Ron,
Ron,
Here is a pic of an intake port on a set of Absolute Speed 5.3 heads that someone posted before. Same situation....
The holes in my TEA heads were a little larger. Again, no problem, but you will need to apply the sealant to those rocker bolts.
Are those TEA reported flow numbers or are they numbers they you flowed on an independent bench?? If not, you should get them flowed to make sure you get what you paid for.
steve
steve
Wow your's flowed better than mine. Here's my numbers.
exh int
55.3 69.2
108.1 139.0
156.8 200.8
218.2 249.0
246.6 280.8
254.3 294.2
261.3 298.6
-Wes
exh int
55.3 69.2
108.1 139.0
156.8 200.8
218.2 249.0
246.6 280.8
254.3 294.2
261.3 298.6
-Wes
wow i didn't know about holes being in the frickin intakes...that's ridculous for what people are paying.
I just received mine today and after looking at them they do in fact have the holes in the intake port mentioned above. I guess I will have to go and get some black silicone. Thanks for the heads up Tin Indian. I would not have noticed this if I had not read your post.
Does TEA usually ship a flow sheet with the heads? I do not think I have one for my heads but I noticed on the invoice that they did charge $50 for flow testing the intake and exhaust ports.
So, you guys want to bash a shop that is putting out some of the best bang for the buck heads around? Come on
Albert
Albert
i never heard of them charging to flow them? It should be free since they have to do that anyway to make sure they are up to par. Maybe they do, but i really dont know..
oh well.. still great heads for the buck! Still waiting for mine. Brent was waiting on the springs to get there from COMP... arghhhhh
yah...yah i am bitching about the fact that there are holes where there shouldn't be in a set of $1800 heads...is there something wrong with that? i was going to purchase them before this post...but now i'm not...i'm not gettho rigging anything with silicone after paying darn near 2 grand for it.
I can shift faster than you.
Jason
I am very happy with the heads I received from TEA. The holes in the intake ports seem like a very minor thing. I would rather have the holes and a great flowing set of heads than have a set of heads that were not ported as well.
The only reason I mentioned the flow sheet is because I always see people posting the flow numbers for their heads and thought that TEA included a flow sheet with the heads. The price of flow testing the heads is included in the sale price of the heads.
Albert
Albert
steve
I think the thing you're losing site of here is that this is common with ALL ported heads if they remove any material at all.. It's not like were fixing a screw up with some silicone and a prayer. If you want to blame someone for a screw up, blame GM for making the boss for the intake bolt so damned big... the bolt goes nowhere near the bottom, and if they hadn't tapped the boss so deep into the head, we wouldn't be having this conversation.
