View Poll Results: Which rod bolts???
Katech
46.67%
ARP
53.33%
Voters: 30. You may not vote on this poll
Which rod bolts?
Old 08-12-2007, 02:09 AM
CaMaRo67RS355's Avatar
Exclamation Which rod bolts?
Doing a head/cam swap what rod bolts Katech or ARP???
Old 08-12-2007, 10:43 AM
Specialized's Avatar
ARP are alright for most- what are you looking to spin to? Do you care if you pony up the extra cash?
Old 08-12-2007, 10:55 AM
team39763's Avatar
I went ahead and put the Katechs in mine because I knew for sure I didn't have to resize/rebalance the rods. I wasn't sure about the ARP's because I had seen so many different opinions. But I'm sure either one will work for you.
Old 08-13-2007, 06:36 AM
anyone else wanna chime in?
Old 08-13-2007, 07:01 AM
m6speed's Avatar
katech
Old 08-13-2007, 04:14 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I have always used ARP fasteners for all internal motor work. 2 LS1's with never a single rotating assembly issue.
Old 08-15-2007, 10:16 AM
i fellow told me ---> ARP bolts are longer and have a higher torque spec. Without removing the rods and having them re-sized for the new torque I'm affraid that they slightly distort the roundness of the rod journal. The Katech bolts are more like the stock ones, just made of better material.
what do yall think?
Old 08-16-2007, 10:23 PM
anyone have anything to say about that ^^^
Old 08-16-2007, 10:29 PM
5_02ls1's Avatar
Default lol
what do yall think?
there was a pole on that last month...it turned out most people used the arp bolts......ive always used arp fasteners.....go with a name you can trust thats been around awhile.......
Old 08-16-2007, 10:32 PM
Tainted's Avatar
i went the with ARP 2000 bolts. they are a very nice peice and im gonna be spinning to around 6400
Old 08-17-2007, 10:45 AM
i just dont need anything breaking so when i was told that it made me worry
Old 08-17-2007, 07:26 PM
blackn2oss's Avatar
i used arp 2000 in my rods i never had them balenced or resized! and i shifted at 6500 on spray and never had a problem! i just tore my ls1 down and the rod journals looked great!
Old 08-18-2007, 07:52 PM
02SOMWS6's Avatar
go with the Katech rod bolts
Old 08-19-2007, 12:29 AM
helicoil's Avatar
Default Katech bolts
Katech bolts weigh the same, are the same length and require the same torque. All of this equals a rod bore that is sized as it was from the factory. The ARP's are 3 grams heavier per bolt (6 grams per rod).
When I balance an engine I am shooting for component weights within a gram of one another and rotating and reciprocating weight within 3 total (on the high side).
You be the judge on how happy you want your engine to be.
Bothe seem to have worked for people. The ARP's WERE NOT designed to be a direct replacement like the Katechs. The Katech fastener is of VERY HIGH quality, it surpasses the ARP in terms of tensile strength.
Old 08-19-2007, 12:52 AM
Asmodeus's Avatar
Is Katech still making those? I thought he stopped making the rod bolts.
Old 08-19-2007, 08:07 PM
they are on there website still
Old 08-20-2007, 02:09 AM
Tainted's Avatar
tck, they got them, but look at that price tag! w000000000!!!!
