This is "GOOD" deal or a "NO" deal?
Read this, this is a complete package that I can get from a very good automotive shop here in Nebraska. Are the part listed in these three packages good parts or not? Any help would be thankful, I was planning on a setup like this after I save from christams till mid summer. Devin
LT1 Camshaft Package #1
$645.00 $612.75
Save: 5% off
LT1 Camshaft Package 1 Consists Of The Following:
Your choice of Comp Cams camshaft
1 set of Comp Cams beehive springs,retainers,locks and locators.
Part#s 26918-16,787-16 ,648-16 & 4705-16
1 set of Comp Cams Hi-Tech pushrods. Part# 7940-16
LT1 Camshaft Package #2
$965.00 $916.75
Save: 5% off
LT1 Camshaft Package 2 Consists Of The Following:
1 set of Comp Cams Pro-Mag Roller Rockers (Self-Aligning) Part#1318-16
LT1 Camshaft Package #3
$975.00 $926.25
Save: 5% off
LT1 Camshaft Package 3 Consists Of The Following:
1 set of Comp Cams Pro-Mag Roller Rockers (Non Self-Aligning) Part#1302-16
Set of 8 GMPP Guide Plates Part#14011051
Set of ARP 3/8" Rocker Studs Part#134-7101
So what you guys think?
$645.00 $612.75
Save: 5% off
$965.00 $916.75
Save: 5% off
$975.00 $926.25
Save: 5% off
I think you could put together a better deal by yourself. There are shops that will custom grind you a cam of your choice or you could look on ebay for comp cams products. You could get a cam for around 240 and they will usually let you choose. any cam that is a production run. You could get normal roller rockers and guide plates for pretty cheap. I just picked up guide plates from summit for like 17 bucks, and hardened pushrods for 40. You really dont need the arp studs unless you wanted to go with 7/16 studs. but you probably dont need them. If I was you I would just get cam and lifters, which on ebay you could get for around 450 shipped, and get rockers and pushrods and guide plates from summit or ebay. Just do a little shopping for the best deals. Also check the feedback from people you buy from on ebay because you never know what could be a scam. Pm me if you have any questions.
Bobby
Bobby
