converter to 'loose'
Old 08-14-2007, 07:52 AM
snkeater's Avatar
Default converter to 'loose'
I own a 01 trans am and i just got a n/a converter "custom" along with my stock tranny re-enforced and shift kit installed. well the converter is to loose in order for me to pick up 40 mph (driving normal) my rpms are between 2 and 2.5. from reading the sticky i guess its called the converter being loose. well ok my question is this, how (if any possible way) can i get lower rpms while tryin to pick up speed?? maybe a tune?? anything?? thanks for your imputs
Old 08-14-2007, 08:54 AM
Moderator
jimmyblue's Avatar
Your slip (which might be 500RPM or more down low)
sits on top of your geared-RPM. You could upshift early
(tune) and take slightly more slip on top of lower geared-
RPM for a net win, or you could bring in the lockup at
low pedal (but I find it annoying, lots of lock/unlock in
street driving). Tune also. Beyond that, the converter
has its nature and you're seeing it.
Old 08-14-2007, 03:16 PM
AK's WS6's Avatar
Thats right on par with how my SS3800 acts. I wasn't a huge fan at first, but I just kinda got used to it and drove the car with a light foot around town and now I barely even notice. Give it some time.
Old 08-14-2007, 04:48 PM
'91firebirdformula's Avatar
i have a 3600, is the locking and unlocking a normal thing??
Old 08-14-2007, 05:06 PM
AK's WS6's Avatar
Ummm, yeah. it will lock every time you hit 40ish MPH and unlock every time you hit the brake and then re-lock when you get back in the throttle if you are above 40 MPH and it will un-lock if you punch it, but again it will re-lock once you get back into the throttle if you aren't on it hard. It all should be pretty seamless, unless you are having other issues.
Old 08-14-2007, 05:16 PM
it will unlock cruising down the interstate, then lock up again a few minutes later. i've tried tapping the brake when its unlocked to see if it will lock back up when released, but no luck.
Old 08-14-2007, 05:39 PM
radz282003's Avatar
The way I drive is unless I am out of traffic and doing sustained freeway speed I leave the shifter in "D". After I am out of traffic and sustaining a speed above 50 MPH I leave it in "OD". You could adjust the lock-up lower but it will lock and unlock a lot more, or if you adjust it higher it will just feel looser.
You may consider going with a shorter rear end ratio. This will help it feel looser, although it's at an expense of higher RPMs which will lead to faster engine wear and increased fuel usage.
Good luck. Try to give it time to get yourself used to it. After some roll races you may change your mind
Old 08-15-2007, 07:47 AM
snkeater's Avatar
cool thanks for your imputs
Old 08-15-2007, 09:03 AM
Moderator
jimmyblue's Avatar
That's misfires, if it unlocks and then locks up on its own a bit later.
At least on LS1s, I don't know about the scheme on older stuff.
Old 08-15-2007, 03:45 PM
ok, so i need a tune-up? or do i get this fixed with a tune?? I know the plugs are getting old and the car hasnt been tuned since i've made it a full bolt on car. Thanks for the inputs!!
Old 08-16-2007, 05:06 AM
tiresmokeLS1's Avatar
Regarding the lockup issue, you can delete (not clear) the misfire codes in the rev range that's causing problems. You need a tuner to do this, or tuner software.
In terms of changing the feel of the converter, there's not much you can do short of a rear gear swap or converter swap. You could play with the lockup settings, but that's not going to be very practical in stop-n-go. Lowering the part throttle shift points will get you into a *slightly* lower rpm, but it may feel even worse, as you'll now need even more throttle to get it to pick up. Give it a little time, get used to it, then see if it still bothers you. A lot of people are annoyed by the "loose" feel right after a conv. swap, but usually they forget about it when they realize the performance gains.
