When do fans kick on?
Old 08-15-2007, 04:56 PM
b3av3r's Avatar
Default When do fans kick on?
Alright I am in louisiana and we have been getting crazy hot temperatures the past couple weeks so I try and not drive my car at all, but the few times I have it has overheated a little.
It will go past the 210 mark just a little bit if I get stuck in traffic or sit still, but once I get moving good again it will drop back down to either right on 210 or a hair below it.
Last night I changed my oil and decided to check my fans. The passenger side fan kicked on as soon as the car started (and I believe it is hooked to A/C?) but the driver side one never came on and I let it idle until it was right on top of the 210 mark.
So when exactly are the two fans suppose to kick on? I would rather know before I decide to jumper the driver fan to make sure it still works.
My entire cooling system is stock including the thermostat.
Old 08-15-2007, 05:05 PM
2001NBMZ28's Avatar
What year is your car? I'm thinking both should run at low and high.
Old 08-15-2007, 05:32 PM
b3av3r's Avatar
Its a 2001
Old 08-15-2007, 05:37 PM
Strahley's Avatar
Just a heads up, the 99 and newer temp guages are dumby guages. If you want to see the actual temp, you'll need to get an aftermarket guage and hook that up
Old 08-15-2007, 06:05 PM
TheSilverOne's Avatar
plus it being an 01 = time for a coolant change
Old 08-15-2007, 06:10 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
If you want to know EXACTLY...take it to a rad shop while running warm/hot...and get them to put their laser temp gun on your hoses..upper and lower...thats what I did..then programmed it 20* cooler or so...[VINCI HANDHELD]....BTW---When you turn on your A/C ...the fans SHOULD come on right away.
Old 08-15-2007, 08:15 PM
b3av3r's Avatar
I've changed the coolant twice on the car and its got about 160,xxx miles on it.
I am less interested in the exact temp, the stock gauge is fine for me, I am more interested in whether my driver side fan is dead.
Is there a set condition(s) that must be met for both fans to run?
Old 08-15-2007, 08:25 PM
DevilmonkeyWS6's Avatar
could be a fan going out mine did the same thing except the screw came off the motor that held the fan on so i just bought a new motor and slapped it in there. took maybe 30 minutes
Old 08-15-2007, 08:49 PM
NHRAMAN's Avatar
Exclamation
You should be more interested in the ACTUAL TEMPERATURE.!!!.. STOCK GUAGES are VERY inaccurate....ALSO--like I said, both fans should come on when you first put on your A/C.
Old 08-15-2007, 09:03 PM
sixvi6-camaro's Avatar
Just as NHRAMAN said.. Ac on fans will be on. try putting the AC on MAX and they will both turn on. Other than that a stock tune will kick the fans on at a very high temp.
fan 1 226 on / 219 off
fan 2 234 on / 227 off
When you shut off the engine (key off) if the engine temp is above 235 the fans will run for 150 seconds after the car shut off to help cool it down.
Old 08-15-2007, 09:14 PM
Restricted User
socmguy's Avatar
If you're thinking it's a switch, a good thing to do would be to buy slp's manual fan switch. If it's off they'll still come on @ the normal time but you can manually turn them on to hi or low.
