Changed wastegate springs, need some advice
Old 08-23-2007, 09:30 AM
00Z-28Maro's Avatar
Default Changed wastegate springs, need some advice
I changed out my wastegate spring the other day and went from a 7lb spring to a 5lb spring. When I get into boost not I can't get over 6.5 psi even with my EBC turned up to 9. Is there any settings on my Eboost2 that I can adjust to get it working right again or is it something else. Everything worked fine before I changed the spring.
Old 08-23-2007, 04:18 PM
ABeasst's Avatar
turn the eb2 up higher. The numbers arent actually the amount of boost just a number. For instance setting on 9 on my car might make 10# on and your car 6.5#.
Old 08-24-2007, 10:40 AM
00Z-28Maro's Avatar
Thanks Adam, I'll have to try that next time I get a chance to mess with it. It had been reading about 2 psi less than my boost guage but that was because one is reading pressure at the turbo and the other is at the manifold.
Old 09-02-2007, 11:35 PM
00Z-28Maro's Avatar
Ok I tried getting more boost out of it friday and when I turn it up the most I get is ~7.5#s. I tried 9, then 12, then 15, then 18, no change (still ~7.5#s). Next I set my boost setting back to zero and got on it so it would know how much boost there is off the wastegate and got the same results when I tried turning it back to 9 again. Anyone ever had an issue like this? I'm about to put the 7# spring back in and say screw it.
Old 09-03-2007, 09:30 PM
RW99's Avatar
Clearly your EB2 is not functioning to control your boost; but the problem is probably plumbing so don't panic. Check your reference lines for both your EB2 and your BOV; perhaps one has been disconnected in the spring swap? And why are you going down from a 7 lb to a 5 lb spring and still using a boost controller, anyway? Just curious.
Turbosmart hosts the document for the Eboost2 manual, I'd suggest downloading it and giving it a thorough reading. The damn programming is not fun to set up, but the instructions are complete. As stated above, those numbers for boost setting have no connection to any psi value... but it's important to put that set point back down low after you make any changes to fix your problem, and then raise it in increments as you did before.
Old 09-03-2007, 10:04 PM
ABeasst's Avatar
it could be back pressure pushing the gate open.
Old 09-03-2007, 11:59 PM
black98ws6ta's Avatar
First I would make sure you have the eboost wires right to the silnoid, then check that you have the vaccume lines correct. The adjustment on the eboost2 goes from 0-100, I think it took quite a bit of gain before I seen a big increase.
Old 09-04-2007, 10:13 AM
RW99's Avatar
Just for your reference, an EB2 boost setpoint of 18 takes me to 11.5 psi from a base 7 psi (wastegate spring only). This is on a T67 front mount, 346 ci.
Old 09-04-2007, 07:13 PM
00Z-28Maro's Avatar
I changed the wastegate spring back to the 7# one. For some reason mine has always been about equal between setpoints and psi. When I set it to setpoint 7 I would usually see about 7.5, if I set it to setpoint 9 I would see around 8.9. It seems to be working fine now. I'd still like to know what setting I missed changing last time but I'm not gonna swap them again to find out. Trying to start those screws while holding the cap in place is a pain in the a$$ for sure. Thanks for the advice everyone, I can live with the 7 PSI lower boost setting.
Quick Reply: Changed wastegate springs, need some advice
