need help with trans
im putting another trans in my 89 astro van. its the awd. does anyone know wat kind of trans it is. im lost. i got a th350s and th400 around and they dont look alike. any one have any ideas.
LS1Tech Sponsor
Well any 4x4 700r4 will work, the case should have four bolts holing the dust cover on but dont refuse a 6 bolt as you can cut the ears and it will clear also , If you look you will se where GM did the same.The cases in either situation will have a K on the bell housing
__________________
ooooo i think i see what ur saying. my awd astro van has a 700r4. your saying i can get a 700r4 out of a 4x4 truck and swap the tranfers cases? so swap out the 4x4 case for the awd case. thanks for all of your help. i really appreciate all of your help
