LSx lifters in Gen I, II, lt block
Old 08-29-2007, 10:43 PM
Bowtie_Aaron's Avatar
Default LSx lifters in Gen I, II, lt block
i heard from a friend that you can run LSx lifters in a Gen I, II, LT based block.
i have a vortec truck block (96), basically an LT block but with std cooling, and rear dizzy.
i did some searching, and could only find the lifter diameter, thats at .842 which is standard SBC.
now, my queston is, are the overall height of the LSx lifters any taller, and would they work with the stock spider and retainers?
i read an article in Car Craft that you cant use a cam over 530 lift with stock lifters, as the cam is ground on a small base circle, and the lifter will have an easier time falling out of its retainer.
how true is this? anyone running a cam over 530 valve lift?
the cam i ordered is the lunati voodoo roller 60122 specs at 535/550 lift 231/239 duration with a 110/106 lsa.
thanks.
aaron
Old 08-29-2007, 10:44 PM
Revelation Z28's Avatar
lots of guys use LS7 lifters in their cam swaps. they work.
Old 08-29-2007, 11:02 PM
Formula_LT1's Avatar
My cam is .540 lift and I'm using new but factory hydraulic rollers.
urbanhunter44's Avatar
i've got a set of LS7 lifters in my garage...
Old 08-29-2007, 11:05 PM
^^ they should be in your engine, what are they lifting in the garage?
Old 08-30-2007, 12:18 AM
TwoFast4Lv's Avatar
I have a few sets of LS7s laying around. They will wrok good just check your Push rod length
Besides I have morels in my engine
Old 08-30-2007, 12:22 AM
In-Zane Moderator
ZONES89RS's Avatar
My XE roller for my 89 is .520 .540 lift and i didnt have any issues with my stock lifters.
Old 08-30-2007, 12:53 AM
TwoFast4Lv's Avatar
My SSEFI custom with .608/.620 did not like my stock lifters or my Comp "R"s. It does like my Morels
Old 08-31-2007, 05:18 AM
96capricemgr's Avatar
MANY guys go over .530 on stock lifters, myself included, on a standard base.
Old 08-31-2007, 07:03 AM
the only thing im worried with is this cam seems to have a real small base as compared to the stock l31 cam.
whats the difference with the ls7 lifters? are they much taller? and are they the same as ls2 lifters?
thanks
aaron
Old 08-31-2007, 09:38 AM
TwoFast4Lv's Avatar
I ran Stock lifter since before your car was even made. They were always objecting but they worked.
My Morels were worth more HP on the dyno...go figure
Quick Reply: LSx lifters in Gen I, II, lt block
