intake manifold question
Old 08-30-2007, 12:40 PM
Z28_DAD's Avatar
Default intake manifold question
is it possible to run a SBC manifold on an LT1? the only differance i can think of would be the coolant crossover on the SBC manifold.
i would like to run an single plane, but noone makes them for LT1s
Old 08-30-2007, 01:00 PM
thesoundandthefury's Avatar
Yes it can be done, and there are people who will do the conversion to make it work:
Brett Bauer
Eric @ intakeelbows.com
I'm sure there are others.
Old 08-30-2007, 01:07 PM
Z28_DAD's Avatar
hopefully they will chime in and give a little info on what needs to be done
Old 08-30-2007, 01:09 PM
TwoFast4Lv's Avatar
GM makes two manifolds.
You can convert any SBC by welding up the hols and re drilling and spot cutting the bolt hole then resurfacing the intake to true it up
Old 08-30-2007, 02:25 PM
Formula350's Avatar
I know it sounds redneck, but couldn't you just JBWeld the holes up? My buddy JBWelded the side of his block up where it had a hole in it LOL It held forever.
Old 08-31-2007, 12:16 AM
In-Zane Moderator
ZONES89RS's Avatar
All the ones i seen had the SBC I holes drilled in the LT1 heads.
Old 08-31-2007, 12:20 AM
TwoFast4Lv's Avatar
Got me again. None of the ones I have seen in person have...
Old 08-31-2007, 12:49 AM
In-Zane Moderator
ZONES89RS's Avatar
They were done at a machine shop, i thought i was buying a Super Victor off a LT1 with the holes drilled in it, when i got it there were no holes, i looked at the heads and the new ones were there, he said there was no sealing problems like if the intake was drilled, no need to cover the pre existing holes.
Old 08-31-2007, 12:51 AM
Formula_LT1's Avatar
The older LT1 heads actually have a place on the head where it could be drilled and tapped for a conventional SBC intake. My 94 heads on my car do, but the factory 97's did not.
Quick Reply: intake manifold question
