best head studs?
Old 08-30-2007, 08:31 PM
single digit dreamer
parish8's Avatar
Default best head studs?
seems like there are some higher quality head studs than the standard arp's but i can't find any info on them.
do they make a better set? if so where can you get a set?
Old 08-30-2007, 08:40 PM
ninetres's Avatar
What's the details about these L-19 studs I read about? Are they a direct fit? Or do the heads/block need to be modified to fit them?
Old 08-30-2007, 08:44 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
A1 fasteners, they can make a stock diameter stud that will take 140lb/ft tq.
Old 08-30-2007, 09:24 PM
TT-TECH Veteran
Inspector12's Avatar
ARP makes the L-19 studs the are about $450 for a set. I have them on the black car and the orange car has 1/2 inch head studs both seem to be working good.
Old 08-30-2007, 10:33 PM
Bill Reid's Avatar
...maybe give Kurt a shout over at W2W... did you pop the 5.3 heads?
Old 08-31-2007, 12:19 AM
c0ncEpT's Avatar
If I remember right he has a prob pushing water under high boost
Old 08-31-2007, 06:19 AM
parish8's Avatar
i am blowing out head gaskets at moderate boost and super safe tune, this is on my truck. 5.3 is running strong so far. i have some kind of problem with my set up right now. my first step is a fresh set of head studs but i was thinking about upgrading from the standard arp's.
Old 08-31-2007, 07:45 AM
speedracer5532's Avatar
The ARP L19 studs just screw right in, no modifications needed and you torque them to 100 ft-lbs vs the 70 ft-lbs of the regular ARP studs.
Old 08-31-2007, 08:27 AM
Mike454SS's Avatar
That much added torque isn't hurting the heads any?
Old 08-31-2007, 12:21 PM
Silverback's Avatar
I'd be more worried about distorting the block/messing up the ring seal if it wasn't machined with a torque plate at that torque.
Old 08-31-2007, 12:35 PM
ninetres's Avatar
Sounds enticing. Is the added price worth it? Do they keep the heads down and the water in better?
Old 08-31-2007, 02:46 PM
Well so far I am running 17.5 lbs with a F1A and no problems. I had a head gasket issue and I talked to cometic and arp and then decided to go with the L-19 studs.
Old 08-31-2007, 03:52 PM
parish8's Avatar
i am running an iron block so that seems unlikely but who knows. i would like to know if there are any down sides to running the L19's at a higher tq.
Old 08-31-2007, 03:58 PM
MY99TAWS6's Avatar
Interested in this topic as going to be doing up new motor soon. I will never go past 20psi likely not past 15psi if go for lsx block 427 with afr 225 heads. I am keeping my fast 90 intake at least for now. So will I need these more expensive arp or a1 studs or will the regular arp with gm mls gaskets be enough?
Old 08-31-2007, 04:09 PM
parish8's Avatar
i have taken the basic arp's with cometics to 18psi on the track and 22+psi on the dyno. above 18psi on the track and i start hurting things but i am not sure if my tune is optimized.
lately i can't even do 14psi so it seems i have hurt something or something is worn out.
Old 08-31-2007, 04:37 PM
stevieturbo's Avatar
deck surface perhaps ? head surfaces ? threads in block pulling ? or perhaps the studs themselves ?
Old 08-31-2007, 06:45 PM
parish8's Avatar
i had the heads surfaced and they still blew out in one run. this time i am going to go with new head studs and recheck the trueness of the heads. we are also going to check the head material. we were told by afr that we want 100 "rockwell" and that 90 was geting too low.
block is iron, studs wouldn't pull out of that would they?
can you check the block deck with it in the truck still?
Old 08-31-2007, 09:58 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I seriously doubt you'd rip a L19 stud out of an iron block. I called ARP a long time ago about them and was going to recommend them to you in your other thread, but was banned. After talking to the ARP guy at the special order shop about them I plan on running them in my new engine. He quoted me $419+ S&H on them if I remember correctly.
Old 08-31-2007, 10:47 PM
Jimmy P's Avatar
I just ordered a set of the L19's from LME. I believe you can only order the L19 head studs through them, because of certain contracts. Total with ground shipping came out to $521
Old 08-31-2007, 11:16 PM
OWN3D BY MY PROF!
Maybe that's something they told you. The ARP guy told me $419 + S&H, but there'd be a 2-3 week waiting period as they didn't / were out of stock (don't remember exactly) of the L19 material.
