can someone check my work? (cam dot to dot setup)
Old 09-02-2007, 09:17 PM
los bastardos's Avatar
Default can someone check my work? (cam dot to dot setup)
I've cranked the motor through 2 complete revolutions but to me the dots just look about 1/2 tooth off.
Attached Thumbnails can someone check my work? (cam dot to dot setup)-img_0190-1024x768-1024x768-1024x768-.jpg
Old 09-02-2007, 09:19 PM
rotated for better view
Attached Thumbnails can someone check my work? (cam dot to dot setup)-img_0190-1024x768-1024x768-1024x768-1024x768-.jpg
Old 09-02-2007, 09:20 PM
Cammin_Z's Avatar
Can't see the dot on the bottom gear in the pic but if its up it would be correct. There is no way to be a 1/2 tooth off.
Old 09-02-2007, 09:23 PM
I should have marked it but my hdd crashed and I lost photoshop, it's on that tooth directly across from the big dot.
I would have thought the same but it just doesn't look right to me for some reason.
Old 09-02-2007, 09:44 PM
TheLS1Kid's Avatar
Pics aren't that great but from what I can see it looks ok.
Old 09-02-2007, 10:06 PM
yeah but it's hard to get a good shot with the pump in the way. Just seems that they line up a little off to the right I guess, if you guys say it's good enough I'll roll with it.
Old 09-02-2007, 10:31 PM
HEMIETR's Avatar
If it were a tooth off you would CLEARY notice it. It looks fine.
Old 09-02-2007, 10:32 PM
cool, thanks guys.
Old 09-03-2007, 12:48 AM
68chevypu's Avatar
is this going in a rx7? or do I have you confused with another los bastardos?
