Is $35 too much
Old 09-07-2007, 02:14 PM
My94TransAm's Avatar
Default Is $35 too much
i am looking at getting some Fel-Pro header gaskets and its going to be around $35 for them. Unless someone else knows of some better ones and please dont say copper seals.
Old 09-07-2007, 02:27 PM
StealthFormula's Avatar
I've always used the fel-pro 1406's on both my LT1's and they've been great and I believe they cost about $17 for a set
Old 09-07-2007, 02:29 PM
The ones I was looking at part # is 1470.
Old 09-07-2007, 02:31 PM
Dragframe's Avatar
i jsut used stock style gaskets
Old 09-07-2007, 04:53 PM
Thats what I really wnat to use, but I've heard a lot of people tell others not to use them. Where can you get the stock style? Aren't they three pice metal? I cant remember.
Old 09-07-2007, 05:25 PM
Schweet97Z's Avatar
Percey's Dead Soft for the win....
Old 09-07-2007, 05:34 PM
fbodyracing1's Avatar
i need to get new ones to im sell runing the one that came with my headers they just started leaking. the ones on ebay are they any good ther made by percey ther 18.99
Old 09-07-2007, 09:38 PM
ExtinctBird's Avatar
I'm pretty sure I used the FelPro 1470's. I put my PaceSetters on over 2 years ago. No leaking or issues here.
Old 09-07-2007, 10:00 PM
engineermike's Avatar
Noooo! With my turbo setup, I got decent life (a few weeks) out of the conventional 1406 Fel-Pro gasket. I got tired of changing them, so I installed Percy's Dead Soft. They lasted less than 10 miles, literally. I then switched to COPPERSEAL and they've gone 2+ years and I've re-used them several times. I will say that the Copperseals are fairly unforgiving if the gasket seating surfaces aren't flat. Some header flanges are horribly warped (namely SLP) so you need the softest gasket possible and the Copperseals won't work well.
Mike
Old 09-08-2007, 02:41 AM
Schweet97Z's Avatar
i got a set of copper seals when i first got my headers and had nothing but leaks with the first start up. then was in a jam and used the ones that came with the headers. eventually they blew out within a couple days. same with the fel-pros and mr gaskets but lasted a few weeks. i put the dead softs in and had nothing but complete sealing from heads to headers lol reused them two or three times so far. i dont think this guy has a turbo on his car either . one person will have luck with something and the other wont. i guess its the luck of the draw.....
Old 09-08-2007, 02:52 AM
smoknta's Avatar
I'm running Fel-pros, and I love them. I got mine at Advanced Auto, and they were under 20 bucks I thought.
Old 09-08-2007, 04:09 AM
Dragframe's Avatar
Mike
damn wish i had known that... guess we will see how long the stockers take the boost.. hehe.
Old 09-08-2007, 09:08 AM
Your header flanges more than likely aren't flat. It's poor QC on the header company but very common. Most people have gasket problems and think it's the gaskets fault, but it's usually not.
Mike
Old 09-08-2007, 10:04 AM
1997bird's Avatar
I have had great luck so far with these Cometic MLS header gasket's sealing. http://www.cometic.com/files/Exhaust...20Domestic.pdf
Old 09-08-2007, 12:30 PM
Hot94Z28's Avatar
I use percy's and dont have any problems. But I'm not running boost either.
Quick Reply: Is $35 too much
