What does a 3,000 stall feel like?
Old 09-10-2007, 03:42 PM
94BlackSSClone's Avatar
Default What does a 3,000 stall feel like?
Hey guys, my biggest fear or uncertainty with getting a stall is what it feels like while driving around the city. I have a 94Z with 3.23 gears, bolt-ons. Is it rough taking off from a red light or does it yank you? Is it only when you are holding the brake that it "launches"?
Thanks for all the help!
Andy G.
Old 09-10-2007, 05:02 PM
GregWS6&z28's Avatar
not a wholeeee lot different than stock
Old 09-10-2007, 05:08 PM
383lt1impala's Avatar
well i had a stock set up in my impala then i went with a performabuilt stage 2 and a 3000 stall and man i love the way it feels some ppl ask me if the trans is slipping but no its just the stall and its bad when u have a loud exhaust and i can foot brake it to about 2600rpm be4 only about 1200
Old 09-10-2007, 05:24 PM
bhz28's Avatar
a 3k stall would feel about like stock as GregWS6&Z28 said.
Old 09-10-2007, 09:01 PM
But driving it at the track would be different if I foot-braked it?
Old 09-10-2007, 09:39 PM
yes. you could launch at a higher rpm. increased shift extension would help you also after the shifts
Old 09-10-2007, 11:03 PM
Pontiacerator
RevGTO's Avatar
Greg says it'll feel like stock because he drives a 4000 stall. To him, it WOULD feel stock. But when I first got my 3000, it felt WAY different from stock. I'm used to it now, but there are some situations when I notice it's there.
3000 is a small stall for an LS1 but a medium stall for an LT1.
Old 09-10-2007, 11:15 PM
Black_Bird's Avatar
Won't feel much different from stock. I had a 3000, then got the tranny built and now have an Edge 3800, it's still not much different besides the fact I can footbrake it to about 3300rpms just on street tires.
Old 09-11-2007, 12:00 AM
Caribe's Avatar
I have a TCI 3500. It felt like it took a little more rpm to get the car going. It was not that bad and you get use to it pretty quick. Now at WOT and launches it felt like a different car. It was so much more fun to drive. Go at least 3500 you won't be dissapointed.
Old 09-11-2007, 09:24 AM
99 BLACKFIRE's Avatar
I just installed a Vig 2800 last friday which stalls around 3200. That is just how Vig rates their stalls. Anyway, Cruiseing at around 50 mph I can tell that it runs at a higher RPM but nothing to extreme. It is alittle different to drive. Under mild excelleration the engine sings more than it used to and takes more pressure on the petal to get it moving but when you put your foot to the floor it puts the power down. If I give it 1/2 to 2/3 throttle from a stop it will burn 'em up. I havent gotten used to my stall yet since I have only had it in 3/4 days so I cant say whether or not I should have went larger, but for now I am completly satisfied.
Old 09-11-2007, 07:15 PM
leoni62486's Avatar
i have tci 3200 not installed yet, im still waitin on my shift kit to come in, but i have the cooler ready, i was told that its gonna be like spinnin the tires like crazy on the street like is it really that much easier to break it loose??? ive never ridden in a stalled car so i dunno what to expect....
Old 09-11-2007, 07:18 PM
leoni62486's Avatar
i also have 3.73 gears, and im already pullin 2k at 55 mph, how much higher u think that will be with the stall installed??? cause i dd mine and do alot of cruisin on highway to work nad back.....
Old 09-11-2007, 07:35 PM
2MuchRiceMakesMeSick's Avatar
I had a yank extreme 3600 on my SS and it wasnt nearly as dramatic as everyone said it would be. But also this is coming from a guy that was daily driving a trex, back when the cam first come out, with dumped duals. After a while I wanted to go with a 4k+ stall but got the z06 instead. Everybodys has different tolerances but I have seen most of my freinds wanting a higher stall after a while and I was no exception.
Old 09-11-2007, 10:40 PM
none at all bc u have lockup.
Old 09-11-2007, 10:43 PM
It isn't hard to break the tires loose but if the street is dry you can keep traction. I just have a heavy foot and I should probabley grow up alittle bit but I don't see that happening anytime soon. Until then I will keep a high tire and gas bill.
Old 09-12-2007, 02:11 PM
TA1364's Avatar
I am the same way, going to be worse once i get a converter.
Ive been wondering the samething tho, how a 3000stall would feel. Im still trying to talk myself into getting one
Old 09-12-2007, 07:02 PM
RooRnZ28's Avatar
i have a 3000 and i can tell a world of difference from stock... the rpms rev higher when you get on it, and i just came from stock tranny/stock stall to the 3000/built trans, and it is a totally different car!
Old 09-12-2007, 08:02 PM
Websy21's Avatar
love my vigalante 3200, and great on the street too
Old 09-12-2007, 09:29 PM
is it smooth when starting off cruising? like from a stop sign? Do ou think a tune would be a good idea?
Old 09-12-2007, 10:33 PM
i420tom's Avatar
You wont regret it get one!!!!
off the line is totally smooth it does NOT rev and then hit barking the tires... it acts just like stock exaclty like stock but with higher rpms. I didnt tune mine.
