Sponsored by: DashLynx
Tropi Care Polish... What Pads ?
Old 09-15-2007, 03:07 AM
SS DNA's Avatar
Default Tropi Care Polish... What Pads ?
I got some TC3 and TC8 recently and I was wondering what pad I should be using the polish with. Is it a white pad ???
Old 09-15-2007, 08:19 AM
LS1TECH Sponsor
Steve P's Avatar
For the TC-8 Swirl Cutter, you can use the orange "cutting/polishing" foam pad or a white" polishing" foam pad on the Porter Cable buffer. Use the lightly moistened orange pad for the more noticeable ultra-fine line/hologram removal from the paint. Keep a spray bottle of water handy to minimize the amount of dust as the product breaks down on the surface.
The white pad may be used after to further refine and smooth the finish before using the blue "final finishing pad to apply the TC-3 Polish/Sealant xP.
Feel free to contact us with any questions.
Old 09-15-2007, 12:25 PM
SS DNA's Avatar
Ohhh So I guess I need a blue pad to use the Sealant/Polish.........
Old 09-15-2007, 04:55 PM
99zee's Avatar
The blue pad works great with the TC3 polish
Old 09-15-2007, 08:59 PM
wannafbody's Avatar
get 2 white,2 orange and 1 blue
Old 09-16-2007, 05:24 PM
Dip Stick's Avatar
what speed should you use to buff it off with when using the gray polish bonnets? 4?
Old 09-17-2007, 10:32 AM
LS1TECH Sponsor
Steve P's Avatar
Once you have worked the TC-8 Swirl Cutter on the surface, it should be broken down where the residue it is almost clear on the surface. Keep a water spray bottle handy while working the product. An occasional light mist will also reduce dusting of the product. Speed 4 is fine for removal with the bonnets.
Old 09-17-2007, 10:39 AM
splitplug's Avatar
What speed should we use for the swirl cutter?
Old 09-17-2007, 10:55 AM
LS1TECH Sponsor
Steve P's Avatar
Removal of the ultra-fine scratches will be easier to accomplish on certain vehicle compared to others. Typically I will use the range between 5-6 on the PC with the orange pad moving at the rate of 1"/second. If you're inflicting micro-marring, lightly mist the work area with some water. Some more stubborn blemishes may require the use of a more aggressive pad and chemical.
Old 09-17-2007, 12:05 PM
SS DNA's Avatar
Smile
Steve,
Does the TC-8 leave Micro Marring ???
and What pad should I use for the TC-3 Polish ????
Old 09-17-2007, 12:45 PM
ArcticZ28's Avatar
Steve,
Running any specials on the TC-8/3 and pads combo? Please?
I do a lot of details and have been wanting to try your product for a while now.
Quick Reply: Tropi Care Polish... What Pads ?
