Tropi Care Polish... What Pads ?
LS1TECH Sponsor
For the TC-8 Swirl Cutter, you can use the orange "cutting/polishing" foam pad or a white" polishing" foam pad on the Porter Cable buffer. Use the lightly moistened orange pad for the more noticeable ultra-fine line/hologram removal from the paint. Keep a spray bottle of water handy to minimize the amount of dust as the product breaks down on the surface.
![](http://i189.photobucket.com/albums/z110/tropi-care/Ultimate%20Detailing%20Machine%20test/UDMtest-15.jpg)
![](http://i189.photobucket.com/albums/z110/tropi-care/Ultimate%20Detailing%20Machine%20test/UDMtest-16.jpg)
![](http://i189.photobucket.com/albums/z110/tropi-care/Ultimate%20Detailing%20Machine%20test/UDMtest-17.jpg)
The white pad may be used after to further refine and smooth the finish before using the blue "final finishing pad to apply the TC-3 Polish/Sealant xP.
Feel free to contact us with any questions.
LS1TECH Sponsor
Once you have worked the TC-8 Swirl Cutter on the surface, it should be broken down where the residue it is almost clear on the surface. Keep a water spray bottle handy while working the product. An occasional light mist will also reduce dusting of the product. Speed 4 is fine for removal with the bonnets.
LS1TECH Sponsor
Originally Posted by splitplug
What speed should we use for the swirl cutter?
