Strange Drag Brakes & Moser Install Question
So I found out why people use a 1/8" bearing spacer to pull the axle out to the backing plate. Burkhart sells the spacers for $50. But that seems a bit steep to me. The question is I have is what keeps a guy from flipping the backing plate around so the bearing is flush mount on the axle tube like the stock backing plate and then just use 1/8" worth of washers on the backing plate to align the rotor to the caliper? Seems to me that would work.
The brackets can be installed on either side of the car though, so they can be installed so the through nuts are installed correctly. Just means the calipers have to be mounted toward the front instead of rear though I think.
Is that the only real issue?
Originally Posted by MADMAN
The offset will be wrong also. Just buy the spacers and do it correctly.
Thx for you time MADMAN, I'm getting ready to install your Arm and will probably call on you for some help setting it up.
Scott
The bearings sticking out a little also help center the bracket since they fit in the pocket in the bracket. That little bit sticking out isnt going to weaken the bearing or anything.
I had to use the spacers too, dont remember them costing that much but maybe they did..
I don't think the backing plate needs to be perfectly center. The mounting holes are pretty tight as it is. The stock backing plate isn't setup this way, why would the strange need to be?
How is the strange 12 bolt different than the moser?
LS1Tech Sponsor
I am trying to give you free advice and experience that I have gone thru. I have installed a ton of these kits and I know the idiosyncrasies of them. Take the advice given by KP who is older and wiser and a chassis builder.
Or you can try it your way and see what happens. Though Tom the Roofer had his the way you are talking and had to buy new backing plates because of things I am telling you.
I dont even think the calipers will even go on the rotors without those spacers and the brackets being the right way. I tried the first time since no one told me about any spacers when I bought them, had to call Billingsly and they told me about them..
