918s hold moderate boost levels?
Old 09-17-2007, 08:05 PM
Quik's Avatar
Default 918s hold moderate boost levels?
would 918s hold the amount of power i want to make? this will be a 408 around 9.1 cr with cleaned up 317s and probably a LS2 intake. im looking to make around 9xx rwhp on pump gas. cam isnt decided yet, nor is rpm range.
would 918s be good for boost or should i go with a dual spring that has better seat pressure?
Old 09-17-2007, 08:07 PM
phildo's Avatar
Don't waste your time with the 918's. They will not support even moderate boost. Get some good duals. Patriot has some good springs.
Old 09-17-2007, 08:08 PM
LS1Tech Sponsor
Superman09's Avatar
dual spring. 918s will only really be good for a car boosting the stock motor so to speak, low boost. Im running them but im on the stock motor and 5.5 psi, working great but with a 408 and big power, def a dual spring.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 09-17-2007, 10:47 PM
gametech's Avatar
My 918's have worked fine on a STOCK displacement 5.7 with STOCK size valves and a STOCK cam at 10#'s of boost up to 6800rpm. Several others have had issues if the boost is increased or if you replace the word STOCK in any of those other areas. My guess is more valvespring pressure will be required.
Old 09-18-2007, 12:16 AM
Quik's Avatar
alright thanks guys, so ill just list them for sale then
Old 09-18-2007, 10:44 AM
JAvenger007's Avatar
patriot gold duals extreme i believe is their heavier duty set. Check into those for your 408
Old 09-18-2007, 11:20 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Use whatever Speed Inc. reccomends on that motor. And 918's won't work on that combo, I would not even run 918's na with a stroker.
Old 09-18-2007, 11:38 AM
koji777's Avatar
Patriot Golds'
Old 09-18-2007, 12:16 PM
SonofaBish's Avatar
wow - looking for some big power... i have the patriot duals...
good luck george!
Old 09-18-2007, 04:05 PM
Quik's Avatar
good luck george!
yea, guess i have to keep up with the jones's ya know
Old 09-19-2007, 01:00 AM
C4 Silver Guy's Avatar
Dammit. I got 918's in my car. Guess I'll be going the dual route myself.
Quick Reply: 918s hold moderate boost levels?
