m6/1.59 60ft or better
im new in the suspension so tell how you got that 1.59 60ft or better
what parts u used,gear,tires,launch technique
i have bmr adj ta
bmr adj lca
qa1 single adj shocks in the rear
mt et slicks 15x26x10,15x3.5skinnies,prostars all the away around
4.11 gears,moser 9"
barely got the slicks took it out to the track best i could get was a 1.85' lanching at 4300 did not bog just thought it should have cut a better 60'broke a fork on that pass so its going into the shop.
i have bmr adj ta
bmr adj lca
4.11 gears,moser 9"
Ouch, 1.85 with all that stuff??? I cut a 1.77 60 ft with stock suspension and 17" mickey thompson drag radials. I guess its all in the launch I spend a good amount of time practicing my launch. I guess what they say is true practice makes perfect.
1.55 60'
QA1's, R's front set on 0? rears single adj, set on 7 right, 6 left.
sphoon T/A,
BMR LCA's
stock springs removed the rubber spacer.
disconected front sway bar.
27-11.5-15 hossier qtp's
12 bolt mosier 3.73's
I dump the clutch at about 6-6500 on the bottle. (stock motor). I have only gotten two 1.5 60's but both were great. Its hit or miss on traction on a preped track. If they just get done laying down vht it hooks but after awhile it just spins. I tried a lower rpm launch but it just boggs after the initial jump. It will lift the front on the street with a 4500 dump but its all over after that lol. Looks good though.
sphoon T/A,
BMR LCA's
1.87
bone stock suspension for 1999, nitto drag radials at 26psi, and a ***** *** slip of the clutch
woot woot.
suspension comes next year, i want to try to get a consistent 1.5-1.6 60fts
woot woot.
i have bmr adj ta
bmr adj lca
4.11 gears,moser 9"
i have bmr adj ta
bmr adj lca
4.11 gears,moser 9"
1.460 on the giggle (604/649 rw)
9" 3.89's, relo brackets, madman shock brackets, single QA1's set on 8
spohn chassis mount t/a
spohn poly/rod ended c/arms
wolfe anti-roll bar
28/10.5's
!front sway bar, bmr k-member, stock struts
3725 raceweight
5500 dump on the gas
7200 dump on motor
got my 4.29's in today so it should do a little better
wolfe anti-roll bar
28/10.5's
3725 raceweight
7200 dump on motor
when you guys say 'dump' the clutch at 5000rpms, do you guys literally clutch all the way in and let off the pedal as fast as you can? i have a mcleod twin and it engages pretty high and if i did that, i could imagine how big of a shock that would put on the drivetrain. would the T56 handle that? i have a PST driveshaft and a Moser 9 with all the UMI supsension. planning on some bogarts with 28x10.5x15 ET DRAGS.
LS1TECH Sponsor
I have cut a 1.51 with standard BMR TA and LCAs with relocation brackets that the welds busted on so they were not solid (found this out later). Had a 4.56 and that was on about a 110 shot. But did a 1.58 with the same set-up on 4.11 gears. Still messed up LCA brackets. Oh and major tire rubbing. Should get back that 1.51 with all that fixed or better this fall.
Im going to get me some bmr relocations and remove the front swaybar and go from a higher launch next time i go to the track (5000).im stil a pu$$y when it comes to launching.definetly more seat time.
For me...
1.54 60ft
90/10's 50/50's
150lb coilovers front eibach drag springs rear
Polyurethane boxed non adjust upper/lower CA
tubular front end
built rear w/ 4.56's
6600-7100rpm launch
..... w/ 304rwhp.
Originally Posted by Bitemark46
Removing the sway bar definately will help weight transfer. One you get adjustable CA's and TA you could have accidently set your pinion angle wrong. Some even get into the positives. Lower the psi to around 12psi hot and try that.
For me...
1.54 60ft
90/10's 50/50's
tubular front end
6600-7100rpm launch
..... w/ 304rwhp.
For me...
1.54 60ft
90/10's 50/50's
tubular front end
6600-7100rpm launch
..... w/ 304rwhp.
just kidding, nice 60ft with so little power.
some of you guys are getting out of the hole nicely, wish i could get those kind of 60fts
2001 z28
1.49 60
stock front and rear spring and shocks
umi adj lca
umi adj tq arm
ford 9 4.33
28 10.5 with 13.5 lbs air
cars 3550 with me in it
stock t 56 with spec 4
3 in steel drive shaft
leave out at 7k on the gas
video of my car leaving out at 7k on the gas in the right lane
http://www.youtube.com/watch?v=8EpsQSzidC4
1.49 60
umi adj lca
umi adj tq arm
ford 9 4.33
