new problem can any one help?
Old 09-25-2007, 08:30 PM
fuseone's Avatar
Default new problem can any one help?
ok so the car had a p1133 code in bank 1 sensor 1 o2 well so i was driving the car and then the ses light went on and i was thinking it was just a bad o2 but now that it went off i dont think its that any more what can the problem be now?
Old 09-25-2007, 11:04 PM
fuseone's Avatar
Old 09-25-2007, 11:28 PM
Copy & Paste Moderator
VIP1's Avatar
Sticky:
https://ls1tech.com/forums/corvette-performance/762697-c5-dic-codes-how-display-them-what-they-mean.html
There may be an intermittent problem, or the O2 sensor is slow to react, or or it could be that the heating element has failed or is failing. Was it cold out this morning?
Either way, scan it again to see if the code is stored or if there is anything else but not turning on the dash light.
Old 09-26-2007, 09:36 AM
fuseone's Avatar
no it wasnt cold when it came on when i started it around like 65 or 70.
Old 09-26-2007, 09:38 AM
fuseone's Avatar
an what do you mean the heating element might be going bad? on the o2 sensor its self?
Old 09-26-2007, 10:11 AM
VIP1's Avatar
To my knowledge, yes.
The O2 sensors on the f-body (and probably all newer cars) have heating elements to get them up to temp quickly on cold days. At least that's what I've been told. I figured that the exhaust gas would be enough for that, but I guess not.
Old 09-26-2007, 10:29 AM
fuseone's Avatar
well only thing i was thinking it was maybe some bad gas or possibly o2 sensor going bad or possible corrotion on the wires of the o2? could there be any other problems?
Old 09-26-2007, 11:15 AM
fuseone's Avatar
also the car does have lt headers and was tuned about 2 months ago if that helps any
Old 09-26-2007, 11:27 AM
Quickin's Avatar
Change the 02 sensor and you'll be fine. Bad 02's.....OR.....FAILING 02's do not always show an SES code. Get an OBDII scan and it'll tell you if they are working properly or on their way out. They don't always just fail 100%, they can fail over a period of time, like weeks or months.
Old 09-26-2007, 11:29 AM
Quickin's Avatar
Everyone thinks it's bad gas at first, and maybe it was, but after going through a tank of gas and refilling, if its still acting up, its not the gas. Its not a bad fuel filter either if you got that code.
Get real, genuine AC DELCO 02's also, Bosch are crap.
Get them here for the same price as the Bosch, real, brand new, AC DELCO.
www.rockauto.com
Old 09-26-2007, 12:03 PM
fuseone's Avatar
yea i really dont think it would be a bad fuel fitler being that i just changed it a month ago ok thanks yea i was going to replace it with a denso or acdelco but was looking for a acdelco if i could find one
