113,000 miles, daily driver - go synthetic or not?
The motor in my car runs very well for the miles, it has some small oil leaks, but I do not have to add any oil between changes. My car sees alot of highway miles, and I probably won't be able to get a new car for two more years, so I'm trying to get the most out of this car. Any suggestions?
You should always use synthetic oil, in anything, anytime, anywhere.
I would use mobile 1 10-40 with 1 qt of synthetic lucas oil stabilizer.
you should be good for over 10,000 miles.
I dont care what they say it is NOT ok to be gay !!
a high mileage oil would be the best to use. synthetic is only best if it has been used from the get go. I have used the Valvoline Maxlife in my 99 TrailBlazer since 95,000 and I have no leaks with 202,000 on the clock now.
Thats not true. My old trans am had 150k miles on it when I switched it over to synthetic and there were NO problems what-so-ever. Everything ran great, no leaks, and held GREAT oil pressure.
JUst put max life valvoline in. Synthetic is just going to make your leaks a whole lot worse. Synthetic is good stuff but your motor has clearenced it's tolerances on mineral oil. I personally like the old mineral oil anyways in lt-1 because of the damn timing cover, I had to put three timing cover seals on my 383 to get it sealed.
Most of the replies sofar are steaming piles of bull written by guys who think watching a TV comercial is "research"
This on in particular is BAD.
Lucas causes foaming, M1 is PROVEN to NOT be a great oil in the LT1.
BlackScreaminMachine and 1bdbrd are the only ones that offered any good info. I would disagree with Black though and say you could switch if you want.
The next big question though is what oil to run and I will say that what most of these yahoos will recommend will likely be a poor choice. They will mostly say M1 5w-30 or 10w-30 but MEASURED wear iron content in used M1 of those weights from this engine in real world use says they are wrong.
1 Post
I switched from Mobil 5w30 to Pennzoil Platinum, don't really have any intentions of going back. From what I've seen, Platinum is far superior to M1. I would never use Pennzoil in anything else, but the Platinum seems legit.
